Chirp/Beep Noise When Changing Transmission Mode
Discussion in 'Gen 3 Prius Main Forum' started by PYTPrius, Dec 11, 2018.
  1. PYTPrius
    PYTPrius Junior Member
    16
    Hi everyone. I have a 2010 Gen 3 with about 93,000 miles on it. For maybe a little less than a year, when I put the car in Park or just push the power button to off, there’s a quick beep/chirp noise that seems to be coming from maybe the back seat area, can’t really tell where. It used to be intermittent but now seems to happen nearly all the time.
    Now, for the past month or so, it’s making the same noise when I put it in Drive or Neutral (probably in reverse too but can’t tell due to the normal reverse beeping. I can just sit there changing modes and it chirps pretty much every time.
    Has anyone experienced this? I’ve searched but couldn’t find an answer.
    Thanks.
    51,155
    not that i recall. maybe the parking pawl actuator is going out, or needs lube
  3. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Yes. I've started getting the chirp on my 2016 Gen 4 when switching out of Park or from Reverse into Drive. It sounds like the beginning of the reverse beep to me.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Wow. Never heard of that one before, so mark me down as a "no."
  5. PYTPrius
    16
    Do you plan on taking it to the dealership? If so, I’d be interested to know what they say.
  6. FuelMiser
    1,342
    922
    Monument, CO
    No, I was not planning on pursuing anything with the dealer
  7. High Mileage
    High Mileage Active Member
    136
    237
    2018 Prius Prime
    PYTPrius, my 2010 now with 260K has been doing the same for a while, still somewhat intermittent, seems more pronounced with cold weather. I have not worked hard to diagnose it yet. I believe it has something to do with the door lock actuator for one of the rear doors. I disabled my reverse beep when I got the car so its not there to cover up noises:).
    I would get someone in the back seat area to try and listen?
    I will take a deeper look at mine. Let us know if you have any luck.
