Chosen Oil Viscosity...?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by GuardianGrayHalcón, Dec 6, 2023.
  1. GuardianGrayHalcón
    GuardianGrayHalcón New Member
    Las Vegas
    2024 Prius
    Limited AWD-e
    Wondering what the general consensus is on Oil for the 5th Gen Prius?
    I know the Factory recommendation is 0W-16 Synthetic however I have seen people opting for 0W-20 or some other alternatives. New to the Prius family and I'm trying to gather information for my own knowledge.
    I live in Las Vegas, NV driving conditions are quite hot in the summer and 30's - 40's Fahrenheit in the winter months.
    Thanks in advance, Prius Newbie...
  2. ColoradoBoo
    ColoradoBoo Senior Member
    950
    624
    Monument, Colorado USA
    Knowing Toyota's engineering, your best bet is to use what's on the oil refill cap 0W-16. It'll even say in your maintenance book that using 0W-20 is okay but only for one oil change, the next has to be 0W-16. It can get down to -20 and up to 110 here in Colorado and has worked just fine in my 2021 that takes 0W-16. If you're worried about high temps, just change the oil often and, also, the radiator coolant.
    GuardianGrayHalcón likes this.
  3. Trollbait
    11,494
    From previous cars Toyota usually calls for changing the oil sooner when not using the recommended viscosity.
    They designed the engine for 0w16, and it is what is used to get the EPA numbers. The viscosity has been out long enough that finding it in the store isn't a problem, and it has been used in Japan for years before manufacturers started calling for its use in US models. Some Toyotas here might be calling for 0w8 now. So I would not worry about using 0w16 when it is called for.
    If everything is working as intended, the engine cooling system should be keeping things within the proscribed temperature range regardless of the season. Using different viscosities seemed more important in colder climates where the oil can end up too thick on start up from what was in past car manuals.
  4. Gokhan
    Gokhan Senior Member
    4,605
    1,848
    Paramount CA
    There is absolutely no need whatsoever to stray from SAE 0W-16 in a newer Prius unless you are driving the car really, really hard and/or fast. The engine barely warms up and/or experiences much torque in regular driving.
  5. Mendel Leisk
    38,634
    IIRC Toyota switched the Gen 4 oil spec from 0W20, to 0W16, 2~3 production years in. Same engine, same car.
    Which leaves me sceptical, of the importance to use one and not the other. Suspect it’d hardly skip a beat, even with say 5W20 or 5W30 (the latter was Gen 2 spec).
    m.wynn and Extricator like this.
  6. Gokhan
    4,605
    1,848
    Paramount CA
    The lowest viscosity that is needed is the best viscosity for your car, as it will result in the best fuel economy, smoothest and most responsive engine, and longest engine life.
    As I said, the exception is if you drive really hard or fast, in which case, a higher viscosity may be better for engine longevity.
  7. Mr.Vanvandenburg
    1,027
    349
    2020 Prius Prime
    Like pulling the grapevine?
  8. vvillovv
    vvillovv Senior Member
    3,596
    1,266
    NY
    0w-16 is not all that much different from 0w-20 . I've used both when changing the oil in the Gen 4.
    Costs can be the same for both 0w-16 and 0w-20 if you shop around on the other hand there can also be a big difference in price if you don't shop around.
    Toyota now makes 0w-8 - but it's easy to get a 5 quart jug of 0w-16 or 0w-20 for the same price as a quart of 0w-8 , no matter where you find 0w-8 for sale presently.
  9. wrtboy168
    wrtboy168 Junior Member
    70
    24
    Northern California, USA
    2024 Prius
    if 0w8 oil becomes more widely available in the future, should 5th gen prius owners consider adopting 0w08 if when the cost of 0w8 would be at par with 0w16? or stay with 0w16 like what the oil cap says?
  10. vvillovv
    3,596
    1,266
    NY
    You might want to ask that question, if / when 0w-8 comes down in price and after more owners have compared it with both 0w-16 and 0w-20 oils.
    Typically the General Consensus Consensus decision-making - Wikipedia
    is to stick with the viscosity that is recommended by the manufacturer. Use other viscosities at your own risk.
    Dyjital likes this.
  11. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    Use what your motor calls for.
    Since ours is 0w-16… continue to use that even if 0w-.005 comes out.
  12. DOHCtor
    DOHCtor Member
    106
    64
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    I have 0w20 in my Gen 5 right now, the reason? I have a bunch of it (Pennzoil Ultra Platinum) and when i used to work at a Toyota dealership, we had a bulletin from Toyota basically saying ''use 0w20 for as long as the shortage of 0w16 persist''.
    When the stash will run out, i'll be tempted to give the Hybrid oils from Amsoil a try.
    https://www.amsoil.ca/p/amsoil-0w-16-100-synthetic-hybrid-motor-oil-he016/
  13. GMAccord
    GMAccord Junior Member
    From Toyota EU site for 2023 Prius PHE, looks like a whole range is acceptable even though 0w16 is preferred. US manuals do not show the range by expected temperature
  14. Gokhan
    4,605
    1,848
    Paramount CA
    This exact thing you posted is a repeated boring discussion that happens on BITOG everyday. If you go there, you will be told to use SAE 0W-40 because of the CAFE conspiracy in the US.
    The truth is that there is nothing to gain in a Prius by going thicker than SAE 0W-16. The engine hardly ever warms up. However, if you use a thicker oil, you will have a more sluggish response and worse fuel economy.
    In fact, the new Corolla, which has the same engine as the new Prius, is recommending SAE 0W-8.
    Trollbait likes this.
  15. Trollbait
    11,494
    Probably because the temperature spread for the oils are virtually the same, and Americans are easily confused. All that graph says is to not use a 5w- oil in near arctic temperatures, otherwise, any of the three is okay. Toyota says to change the oil sooner if not 0w-16 cause the thicker will have a negative impact on engine performance and efficiency.
  16. Bill Norton
    Bill Norton Senior Member
    1,833
    601
    MONW, Ks.
    Are you saying that when I am blasting down the interstate for hours on end at 80MPH engine is not 'warmed up'?
    Are you saying you can quantify statements like: "more sluggish response and worse fuel economy".
    As in, accurate numbers comparing ever so slightly different weight oils?:whistle: That's some detailed testing!!
  17. Gokhan
    4,605
    1,848
    Paramount CA
    I don't think 80 mph is considered a very high speed for Prius—regardless, you should always stay at or below the speed limit by law—but the Toyota owner's manuals always provide a note that a higher viscosity may be better suited for extreme speeds. So, perhaps if you are regularly driving 90 mph or faster, you should use 5W-30.
  18. Bill Norton
    1,833
    601
    MONW, Ks.
    Very good. I drive at most +5 the posted speed limit, so on some local interstates that would be 85mph.
    I'll have to RTFM.(n) It recommends 5W-30 with some duty, in writing? What if it's 0°F and I'm taking a road trip?
    But what about my questions concerning your statements above?
    "The engine hardly ever warms up...."
    "...you will have a more sluggish response and worse fuel economy." As in 0-60 times? A measurable drop in mpg?
  19. Gokhan
    4,605
    1,848
    Paramount CA
    A 1.9% minimum improvement in fuel economy is required for 0W-16 over SAE 5W-30 in ILSAC tests. It is 0.7% minimum required for SAE 0W-20 over SAE 5W-30. You will probably see more benefit if the engine is not fully warmed up. You could see improved protection in extreme cold as well, and the engine could operate more smoothly during warm-up.
    Bill Norton likes this.
  20. DOHCtor
    DOHCtor Member
    106
    64
    2024 Prius Prime
    SE
    Sluggish response... mehhh...
    Reduces fuel economy, yeah a bit..
    Engine hardly ever warms up! Yeah definitely! The thing always start then stops every 2% of indicated battery level.. that is the crap that got out of my engine because of this... 10k km OCI so, 6k miles? Never again! I'm not going over 5k during winter just because of this. Can't get the damn thing at decent oil temps..
    Oh and if you're wonderimg, that was some Pennzoil Ultra Platinum in 0w20 flavor with a YZZF1 OE filter.
