Christmas Tree Dashboard
Discussion in 'Gen 2 Prius Technical Discussion' started by RestedSoul, Jul 17, 2017.
  1. RestedSoul
    RestedSoul New Member
    Tennessee
    Ok, I have read a lot of topics on this, and got home today to do some testing.
    Story, I have a 05 Prius. Bought used, big bad battery was replaced last August. There was no known issues. Drove the car for about 2 months, and I get the Christmas Tree Dashboard, lights galore. I checked the code and it came up as P0a80. Yep I know what that usually means.
    Today I was reading through all the discussions about the dash lights and testing this and that. So I got home, jump started the car, and here are my findings.
    1. The inverter fluid is moving while engine is running, and not running.
    2. Car turned on: Vehicle Signal Check Mode shows battery at 12.8V in diag mode.
    3. Car turned on: Vehicle Signal Check Mode shows battery at 12.3V in diag mode with headlights on.
    4. Car running: Vehicle Signal Check Mode shows battery at 13.8V in diag mode.
    EMV: OK, NAVI: OK, Audio H/U: CHEK, G/W: OK, DSP-AMP: OK
    Lan Monitor:
    EMV: CHEK, NAVI: CHEK, Audio H/U: NoErr, G/W: NoErr, DSP-AMP: CHEK
    Dash lights that are on:
    Red Triangle, Check Engine, VSC, and the !
    HUD shows the red car with the ! on it.
    After turning off the car, the volt meter on the 12v reads 4.15v and falling.
    The car has been sitting since December. Needless to say I have to jump it anytime I need to test or do something. Prior to that I had no problems starting it.
    As long as I jump start it, it starts and runs fine. AC blows cold, everything works, just this annoying Christmas Tree Dashboard. I have not driven it since this first started in December. Closest Toyota dealer to me is about 50 miles away.
    I have been pricing the big bad batteries, and found a place close to Memphis, TN, that has them for under $1500 with a 5 year warranty. Just trying to make sure that is what it is before trying to get a loan to drop that much money. I am still paying on a car that has been sitting in my yard for 8 months. Besides that, I loved driving it, since I work 65 miles from my house.
    Please let me know if there are other things I need to test, I was really hoping it was something cheap and easy fix.
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
  3. Malcolm338
    Malcolm338 Junior Member
    27
    Carlisle uk
    The first thing I would change is the 12 volt battery in the boot I had all the lights on mine changed the battery car works fine now
    Ellen Berman likes this.
  4. RestedSoul
    Tennessee
    I'll take a look at it. I didn't have a problem with the 12v battery until it sat for 8 months. When this problem first starting happening, it would start without any issues. Or is it that the car doesn't start off of the 12v battery? Right now I cannot get it to start or power anything, without a boost. Once I hook up the jumper cables, it fires right up, don't have to let it sit to charge before starting.
  5. RestedSoul
    Tennessee
    Ya not a typo, im afraid. I know that the 12v battery is shot now, but it was starting just fine 8 months ago when these issues first started. I parked it then, as I do not have the money for the other battery.
    Could the 12v battery have been going bad then that is causing me all these issues and check engine code of P0a80?
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes. Although 8 months of sitting is not good for the main pack...
  7. RestedSoul
    Tennessee
    Is the 12v hard to replace? I can afford the $200 ish more than the $1500 ish. Either way I know it needs replaced, just don't want to take it to a shop if it is something I can do easily from home.
  8. RestedSoul
    Tennessee
    Didn't realize a 12v would give you that check engine code. The main battery gauge goes all the way down, then back up after first stating.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes, it takes a few minutes. Easy.
    When the 12v is low, nothing the car does is rational. That's why "replace the 12v" is the most common mantra around. The Prius has a very small 12v compared to American standards, normal for Asian markets. It also takes a while to charge once depleted in the Prius. All the systems use the 12v to start and if it is weak, all sorts of references may be off. Almost any error the car can throw, may be thrown.
  10. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    It is possible that your 12V, when installed, wasn't fully charged and things went downhill from there.
    I'd get a battery charger and try charging it up before replacing it to see if that resolves the problems.
  11. RestedSoul
    Tennessee
    I've heard you got to get a special charger. Only battery charger I have is a 12v charger I got from Harbor freight
  12. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    To charge the 12 volt battery, a 12 volt battery charger should do it. Just follow the directions! (y)
  13. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Anything is possible but you have a code for a bad (used) HV battery and a weak one can also trip numerous other codes/lights. BTDT
    If the car has been sitting for 8 months, the 12v is dead and shouldn't be trusted even if revived so you'll need one of those anyways but your HV batt has failed.
  14. RestedSoul
    Tennessee
    Ya the company was Greentech, something like that
  15. bisco
    49,431
    the 12v fires the computers and relays. the hybrid battery propels the car, charges the 12v and turns the engine over.
    nothing works without a good 12v, and unlike a regular car, more issues are caused by a weak 12v than just not cranking the engine.
    get a new 12v on line for the best price, and find a youtube install video.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    You need both batteries.
  17. RestedSoul
    Tennessee
    I got it fixed yesterday. I called to order both batteries and he showed up same day and installed them in about 30 mins. He services about 6 states, so if you are in need, I would recommend him.
    $1775 for both batteries, tax and installation. 5 year warranty.
    Hybrid Restoration is the company, located in Bartlett, TN.
  18. bisco
    49,431
    congrats, all the best!(y) (let's hold off on the recommendations until your expectations have been met)
  19. Ellen Berman
    Ellen Berman Junior Member
    16
    Wilmington, de
    Three Touring
    Just try unhooking positive 12v battery and rehooking..May be easy fix. This will reset electronics.
