Cigarette Lighter and MPG
Discussion in 'Gen 2 Prius Accessories & Modifications' started by darkgiant, Jan 18, 2016.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I am looking to possibly getting some sort of Bluetooth receiver, something like this: amazon.com/SoundBot-Bluetooth-Hands-Free-Wireless-Streaming/dp/B00RH29CJO/ref=sr_1_12?ie=UTF8&qid=1453099762&sr=8-12&keywords=hands+free+kit+for+car
    The idea is that the car adapter would be plugged into the cigarette lighter in the arm rest area, and would always be plugged in at all times, but my question was, does this overall impact the total MPG? Obviously it puts a load on the battery, but how significant would it be, since it would be plugged in even when the car is off? I understand this is silly as it is a little gadget, but it is just my curiosity to see if there is said impact with using the cigarette lighter all the time and its impact on Miles Per Gallon.
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I don't believe the little bit of power that device is going to pull will affect the MPG. You do realize it will only work when the Prius is in "Ready" mode, accessory mode, or ignition on mode. If the Prius is powered down the blue tooth will not work when plugged into the 12 volt outlet in the console.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Of source everything that you plug in will affect your MPG. But depending on actual power consumption of the devise, your average speed and consumption effect will only be something like 0.1 to 0.002MPG.
  4. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Technically, yes... since it consumes electricity, that electricity has to be generated from the car -- ultimately in the form of fuel being burned.
    In practice though, it consumes so little power that there's no way you could reasonably calculate and observe the difference in MPG.
    I assume your plan is to plug the 3.5mm jack into the Aux input in the armrest? It's not clear in the description if that jack is an input or output.
  5. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    On a trip to California from Michigan I used a large Igloo cooler. I tested the current flow from a fully charged 12V battery and the cooler consumed 3.75 amps current. That is 45 watts. I also ran a 400 watt inverter to run my laptop computer. That power supply uses .5 amps @12 V = 6 watts. so for for the cooler + HP laptop is 45 + 6 = 51 amps.
    The car will supply 100 amps so the inverter + cooler is eating slightly over 1/2 the available watts.
    The result was it worked well, but the current draw was large enough to load down the charging of the HV battery. After several hours of driving I found it harder to maintain 50 mpg. It settled in at 45-46 mpg. the battery SOC (state of charge) dropped to 5 bars and lower. I usually lost charge going up those long mountain roads on the expressway. With the cooler on the rebuilding of the battery charge was reduced and would never get back to 6 bars.
    6 bars is the optimum charge to get the best mileage.
    The solution is to unplug the cooler and drive without the load it imposed. You can plug it in later if needed.
    My ride is a 2004 Prius base vehicle.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I'm going to go through the calculations for giggles. But before I do, I predict the difference is nothing.
    EPA says the energy in 1 gallon of gas = 33700 Wh.
    A random BT car adapter on Amazon uses 0.5 W.
    For comparison, a standard cell phone charger is rated at 5 W.
    Assume you average 50 mph and get 50 mpg.
    50 mpg x 0.5 Wh / 33700 Wh = 0.0007 mpg.
    If you plug your phone in to charge, it's 0.007 mpg difference. Yep, absolutely nothing.
  7. valde3
    2,002
    745
    Finland
    You forgot that only about 33% of energy in gasoline is turned into force at the crankshaft. Then that energy is converted to electricity in MG’s and that energy is fed into converter that turns it into 12V. If we think that inverter/converter and MG’s have combined efficiency of about 90% we get 0.0007MPG/0.9/0.33=0.002MPG difference.
    And when Prius is running engine isn’t running all the time. So when the engine is not running the power comes from the hv-battery (which is then charged back to hv-battery at later time). So we also have to take into account the efficiency of hv-battery and its charging circuit.
    Of course the effect is still nothing. It’s so small that it can not be measured.
    mmmodem likes this.
  8. dorunron
    3,318
    1,103
    Houston, TX
    Common sense will tell you that little bit of power the bt adapter is going to pull is really not going to amount to a hill of beans. I would venture to say a GPS plugged into one of the 12 volt outlets (Garmin Nuvi for example) would pull more than that bt adapter. Stop and think how many out there are doing that, and no one is complaining about MPG loss. As has been pointed out, the Prius has a lot of power to spare.
  9. Cooljourney
    Cooljourney Junior Member
    Florence, AZ
    I just bought this same unit for our 2006 Prius. It works perfectly. I only use it to stream music and use the car's bluetooth for the phone. I can't imagine it affecting the MPG by any appreciable amount.
  10. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Woah, so many responses! :) this was ultimately just a silly question that I was just really curious about!
    And for the questions on how this is used, it would indeed require both the AUX and cigarette lighter to be plugged in at all times (underneath the arm rest of course).
    Thanks for the many responses! :)
  11. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    Good to know! Do you have to manually select one or the other on the phone, or can it connect to both simultaneously?
  12. Cooljourney
    Florence, AZ
    I think it depends on what version of bluetooth you have on your phone. My Android phone has bluetooth version 4.0 and connects to both automatically.
  13. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    BTW: I believe you're off on the laptop. The power supply may indeed only draw .5 amps @ 120V, but the laptop most likely consumes more like 40-60 watts DC, or about 3 - 5 amps depending on the voltage it requires. Then there's the consumption/loss of the inverter -- they tend to not be very efficient).
