cigarette lighter power inverter
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jenny867, Aug 8, 2020.
  1. Jenny867
    Jenny867 Member
    55
    38
    West Los Angeles, CA
    I had a 75W power inverter that made no noise when being used, and I bought 150W that makes a humming noise. Any ideas if the humming noise is a bad thing, a signal that it's too strong? Thank you in advance. Read some threads before posting.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    From the owner's manual,
    If you put a full load on that 150W inverter, I'd expect it to blow the fuse feeding the 12V outlet. I don't think that the inverter should hum, though, just because you connect it to the car.
  3. Jenny867
    Jenny867 Member
    55
    38
    Thank you so much!
    jerrymildred likes this.
  4. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    When I plug in my power inverter to the cigarette lighter port, a built-in fan starts up to keep the internal electronics cool. Are you sure it's not that?
    Jenny867 likes this.
  5. Jenny867
    Jenny867 Member
    55
    38
    It may very well be! It's loud, and I much prefer the 75W one which makes no noise.
    davecook89t and bisco like this.
