City Mileage 10 MPG worse than Higheway Mileage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by karat, Oct 2, 2006.
  1. karat
    karat New Member
    17
    As far as I can tell, I'm supposed to be getting better city mileage than highway mileage for my Prius. However, I'm seeing it definitely the other way around. There are some potential explanations for bad mileage, but none of them really explain this inversion.
    Specifically, I am getting 36.5 mpg in the city and ~45+ on the highway, driving at 65 mph.
    Some relevant factors include:
    1) The car is new. I've seen this behavior from mile 0. I've now got 3700 miles on it and I still see the same influences. Yes, both the highway and city mileage have been improving as I break the car in, but there is definitely a lag between the two.
    2) Weather. Mostly I've been driving in conditions that are close to ideal, but slightly on the warm side. I have used a/c on low. I have experimented with shutting off the a/c, but with no noticable effect. However, none of my experiences have been with winter conditions yet.
    3) I have observed that the engine likes to run a lot to charge the battery. In fact, I have a hard time trying to coax the car into using up the battery. The battery drains significantly when the car is parked, but the car charges it full rather quickly. From my understanding, the car is often in a state where the battery is full and will not charge any more. Thus, I am losing energy because it keeps trying to charge the battery when it is full.
    4) Much of my city driving is in short 10-20 minute trips, sometimes with the car off for less than half an hour between such trips (eg work to grocerty store to home, with the car off while I am at the grocery store). I want to know if this is a strong enough factor to explain my 36.5 mpg.
    Basically, point number 3 suggests that there may be a problem. Point number 4 suggests that there might not be. How can I tell? What can I do? I am going to take my car in for the 5000 mile maintainance, and I can ask them to check something out, but I don't know what to check out.
  2. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I never read anywhere that city mileage would be better than highway.
    Highway driving usually means little acceleration, so to maintain constant motion requires less energy than stop and go.
    The energy you get back coasting and regenerative breaking is only a tiny fraction of what was used to get up to speed. The Prius isn't a In-Wheel Electric. The In-Wheels recoup a much higher % of the energy while breaking.
    What's interesting is how little driving at 55MPH, 60 or 65 makes the gas usage differ.
    Makes you want to always drive at 65mph...
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    Your mileage sounds low to me. I don't understand the part about the battery getting low while parked. If I have green bars when I shut it down, that's what I have when I start it back up. I do notice low mileage for the first 5 or 10 minutes when the engine is cold, but in low speed (under 40MPH) stop and go, the engine is off a lot, unless it's 90 outside and a sunny day, in which case it runs more, but my city always seems higher than my highway.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< karat...
    Your Prius is not "warmed up" or "broken in" yet. There's also a "learning curve" on how to get the best fuel economy. The Prius is a "different" car and while you can "just drive it," you can develop driving habits which will improve fuel economy. Many new Prius drivers report their best MPG results begin at somewhere between about 6,000 miles and 10,000 miles after wearing the moulding "nibs" off the new tires and limbering up the mechanical systems. Some Prius drivers believe that overfilling the motor oil can reduce fuel efficiency, and dealers frequently do overfill. Another fuel-saving technique is keeping the tire pressures higher, I run mine at 40 psi front and 38 psi rear. The 10 MPG difference between highway and in town are almost exactly what I experience after two years and 21,000 miles. Around town (mixed short and intermediate trips), I'lll do about 45 mpg, steady freeway at 65-70 MPH, I will do 52-55 MPG.
    The EPS estimates are made under strictly controlled "laboratory" conditions and don't reflect "real world" driving conditions. For fun, read the language on the window decal - just below the "60 - 51" numbers.
    Enjoy your technical marvel Prius, the most advanced production vehicle available.
  5. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Mark Derail @ Oct 2 2006, 04:36 PM) [snapback]327102[/snapback]</div>
    It is EPA rated at something like 60 city, and 51 Highway.
    I see around 50 on the highway, and 55 on my commute, or better, depending on the amount of stop and go and the weather (AC usage). I've seen 70 MPG on some trips, but that's with a traffic tie up and lots of stop and go, and very little over 40MPH. The engine runs just enough to charge the battery, then the car stays in electric mode until the battery droops.
  6. ditto231
    ditto231 New Member
    65
    Your problem could be number 4. You said short trips 10 to 20 minutes, the 1st 5 minute I only got about 25 to 30mpg. The next 5 minutes about 30-40mpg, but 10 minutes and if I pulse and glide in the city I should get about 60 to 75 mpg.
  7. karat
    karat New Member
    17
    Okay. The three Prius owners I've talked to in person all have better city mileage than highway mileage. All three thought it was strange that I was seeing worse city than highway mileage. It was suggested that I post here for wider opinions.
    I'm aware of the break-in period, but I should have started to see somewhat better mileage by now. Also, most sources do not want to provide numbers. If I can get something more specific than "it's not as good during the breakin period," that would be helpful in setting realistic expectations.
    As for learning curves, I've read driving guides on how to get the most mileage on the Prius. It really feels like they are talking about a different car. (Well, they are talking about a 2005, not a 2006, so technically they are. I don't know if much has changed.) I certainly don't see "warp stealth." Sometimes at low speeds, I can feather the accelerator and convince the engine to coast. My biggest frustration in the car is trying to convince it to neither run the gas motor nor recharge the battery that is already full. Electric engine only mode lasts for about 30 seconds before it tries to recharge the battery. If I try to coast, it slows down the car appreciably while failing to recharge the battery.
    It's hard to tell what I should be learning to do. ("Read a guide" and "maximize the mpg meter" are not sufficient, as I've attempted both.)
    However, the original question is "Is 36.5 mpg in the city while I'm getting 45-50 on the highway at 65+ mph reasonable for my situation, or is there a potential problem? If there is a potential problem, what can I check to prove/disprove this?"
  8. Tideland Prius
    16,534
    <div class='quotetop'>QUOTE(Mark Derail @ Oct 2 2006, 01:36 PM) [snapback]327102[/snapback]</div>
    It's rated 4.0/4.2L/100km according to Transport Canada. I'm probably one of the rare few that gets city > highway mileage. I average 4.4L/100km over the summer while on the highway (usually to the States), it's 5.0L/100km at 70mph.
    <div class='quotetop'>QUOTE(karat @ Oct 2 2006, 02:16 PM) [snapback]327132[/snapback]</div>
    #3 concerns me. Why would the battery drain while parked? It should be exactly the same level as you left it before you shut off (unless it's on the borderline between two levels). Are you trying to use the battery? If so, that might explain the low mpg. Using the battery in EV mode means the battery will drain and if the battery drains, the engine will recharge and bump it back up to 6 bars. Try to use the engine more often and not the battery. It sounds counterintuitive but you will get better mileage.
    Take note the difference between coasting and gliding. What we call "coasting" is when the accelerator pedal is NOT depressed and the electric motors are recharging the battery via regenerative braking (green arrows to the battery). "Gliding" is when the engine is off and there's no arrows to or from the battery.
  9. chimohio
    chimohio New Member
    460
    I've got just slightly under 2000 miles on mine and also see lower mileage in town, mostly suspected to be due to not yet broken in and definitely shorter trips. Fremont OH is a relatively small town and it doesn't take long to go from place to place so much of my in town driving is short (10 - 20 minutes) but I don't see any where near the 60 - 70 - this gives me something to strive for. I probably average about 45 mpg in town, and have been averaging 50 on longer drives to work. Have not noticed any battery issues.
  10. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(karat @ Oct 2 2006, 05:16 PM) [snapback]327132[/snapback]</div>
    You're not driving in "B" instead of "D" or anything like that? "B" stands for engine braking, and some people reportedly think it means "Battery" or something...
    Tire pressure OK? I had a slow leak, and was driving around with 25 lbs or so, and noticed a mileage drop.
    I can't remember exactly when my mileage got better, but I thought I was seeing in the 50's after 2500 miles or so. I know the first 1000, I never got above mid 40's for the most part. I'd expect to see much better mileage that what you are getting, especially on the city part, assuming you are not trying to recreate the Fast and the Furious from stoplight to stoplight or something like that. Could be your trips are just short enough that the engine never fully warms up, I suppose, but if you can go for a longer city drive and see what you see on the "consumption" dispaly after 15 minutes or so of city driving. I'm assuming these are the same between an '05 and an '06. I know that for my stop and go commute, it doesn't hit the plateau until about 10 or 15 minutes in. The first 5 minutes is like in the 20's, then the next in the 30's and then it levels off in the 50's.
    The part about the battery level dropping while parked, i.e., I assume with the car off, definitely sounds like a problem. I'd note that for when you talk to your service dept., that should not be happening, but without seeing the displays, it's hard to say what you are seeing.
    Beyond that, and I think I know a lot about cars, not sure what else could be be wrong, or even what the average person could really check even if someone had an idea. It's a new car, it's under warranty, call your dealer's service dept. and have them check it out.
  11. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(karat @ Oct 2 2006, 04:21 PM) [snapback]327087[/snapback]</div>
    I believe the main reason is #4. For the first five minutes, I NEVER get over 25 mpg, sometimes much less. The second five minutes is more, but usually not more than around 40. Usually, even after the car is completely warmed up, after stopping for 30 minutes at a store, the first five minutes after restarting is pretty low again, around 25 mpg. On the highway, I generally get over 50mpg (even during the first 1000 miles or so), but I think it's because I take longer trips on the highway.
  12. richard schumacher
    7,664
    1,045
    United States
    <div class='quotetop'>QUOTE(karat @ Oct 2 2006, 04:16 PM) [snapback]327132[/snapback]</div>
    That sounds like you're in "B" and not in "D". "B" should be used only when going down a very long steep hill, as an alternative to riding the brakes. In Boston there is never a need for "B".
    10 minutes trips with the A/C running definitely kill fuel economy. The EPA figures, which Toyota is required to publish, are not realistic for the way the Prius works. Most people find that their highway fuel economy is better.
    What did you mean by the battery running down while parking? If you meant something like "parked with the car READY and the A/C on while I wait for my mate to use the ATM", then draining the battery down to two bars is normal. If you meant that you believe the car is turned OFF, as though you're leaving it for the day, then draining the battery is not normal.
  13. tmgrl3
    tmgrl3 Member
    315
    The first five minutes is a killer for me...also, I have lots of HILLS....
    My first tank of gas (I do no highway driving) was 30 mpg. Then I really maximized factors I read about here...tire pressure upped, and driving techniques...Second and third tank of gas...42, 44 mpg.
    I now "bunch" my errands in one day...taking the longest leg of the trip first, if I can...that may only be a 10-20 minute drive on local roads, but the ICE is warmed up...by the time I near my first destination, I can use P&G nicely, I go into electric only (all yellow arrows) for some slight up and downhill runs...and then coming home I have lots of "coasting" (downhill ...no accelerator at all) to get regen....
    This article helped me a great deal initially, although there is a good deal of information here at PriusChat.
    http://www.hybridcars.com/maximizing-milea...yota-prius.html
    I only have 1000 miles on my car so I am hoping to go up slightly although winter is going to set in and cold weather is the mpg enemy.
    Good luck.
    I ran into some people locally who also said they get roughly 45 mpg around my area. Your locale, trip length, AC use, tire pressure...all factors...but I do feel the driving tips have helped.
    terri
  14. bweather
    bweather New Member
    Hiya, Karat. That mileage does sound low, since I've got 1000 miles less than your car but getting better mileage. Your car should be more run in than mine. I'm wondering about a couple of things...
    1. Short trips and the engine not being warmed up. Do you have time to make a 20 to 30 minute drive and see what your mileage is like in the latter part of the drive?
    2. I've never been to Boston, but I've heard the traffic is pretty scary. Is that so? Do you have a lot of stop-and-go traffic? The EPA estimates are based on longish stretches at low speed, not a lot of stopping and starting, so if traffic is like I have heard, maybe that is part of the problem. Can you test in a lower traffic area?
    If I'm reading correctly, your engine is running to charge the battery until green bars are showing on your charge indicator? I can't think of a reason for that to happen in normal operation.
  15. karat
    karat New Member
    17
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 2 2006, 05:34 PM) [snapback]327138[/snapback]</div>
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 3 2006, 08:53 AM) [snapback]327242[/snapback]</div>
    For reference I am driving in D, not B.
    It sounds like my problem is the battery. I typically lose 3-4 bars overnight every night. However, it charges and just keeps charging until it turns green. Then I turn it off and it can go all the way down to 2 bars again.
    Also for reference, I am turning the car off and the lights off.
    I thought the battery drain was normal due to alarm and keyless entry. Is there anything more specific I can ask the dealer to check out when I bring it in for my first servicing? Is it possible that if I park in a set spot next to another car with keyless entry that we could be draining each other's batteries or something like that?
    I'd be happy if I could get at least 40 mpg in the city.
    Finally, a side question, is the electric engine more efficient than the gas engine? That is, is it better to run the electric engine and have the gas engine charge it or is it better to run off the gas engine as much as possible? People seem to be assuming that the electric engine is more efficient, but this reply suggests otherwise.
  16. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(karat @ Oct 3 2006, 02:20 PM) [snapback]327408[/snapback]</div>
    Yikes! My '05 doesn't do this, and I'd sure notice, since my house is on the lower side, and I can usually glide in and get green bars on my return, and it's there the next day. Sounds like a definite problem. With the car off, the "aux 12v battery" is used for smart key etc. as far as I know. Good luck.
  17. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    The electric engine is about 1/3 as efficent as the gas engine. As all of your energy comes from gasoline. The estimates of efficency after charge-discharge losses from the gurus in the Yahoo Prius technical group generally is about 30%. The magic is that all the other cars throw that away when braking to a stop and then waste 100% while in idle at a stop. The guys who have set the mileage records with the Prius use the electric cycle as little as possible.
    When you car is off, the HV battery is disconnected, so alarm systems, SKS, etc. can't be what is pulling it down.
    I have left my car in a garage for 8 days while on vacation and returned to find the main battery at 7 green bars, just where it was when I parked it. I have seldom noticed more than a one bar drop and I attribute that to the temperature dropping overnite by 30 or 40 degrees (F) and perhaps the battery display being on the edge of dropping down a bar to begin with.
    It might be worth a check at the dealer if you have a good Prius tech there.
    - Tom
  18. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(karat @ Oct 3 2006, 01:20 PM) [snapback]327408[/snapback]</div>
    a drop of that amount overnight, with the car turned off, is serious. take the car to the dealer imediately. The hybrid batteries are disconnected from the rest of the car when it is turned off, and thus shouldn't lose any charge overnight. Of course, if you're right on the edge and it gets extremely cold, you might see one bar disapear, but thats it. if it's going from green (top 2 bars) to pink (bottom 2 bars) when off, there is a serious problem that needs to be diagnosed and fixed - under warrenty.
    And to answer your side question, it's a bit more complicated. Assuming a limitless amount of energy for the electric motor, it is cheeper at current rates to drive on electricity than on gasoline. However, without the ability to plug in the car to recharge much larger batteries, this isn't so. Whenever the ICE runs to recharge the batteries, energy is lost in the conversion. More energy is then lost when running the motor. so you are essentially penalized twice for that energy, where as the same distance traveled by using the ICE directly you're only penalized once.
    The most popular method for driving is pulse and glide, where one tries to accelerate the car while putting the ICE in it's optimal effeciency range (about 70% RPM, but with no tachometer it's hard to tell), then easing up and gliding with no arrows on the MFD down again, and repeating. to get no arrows on the MFD, you have to feather the accelerator a little bit. Of course, this strategy shouldn't be employed at high speeds (anything above 40 and the ICE won't turn off, thus the idea of warp stealth to "do your best") or in traffic, as it creates a potentially dangerous situation.
  19. bgdrewsif
    bgdrewsif New Member
    497
    Phoenix, Arizona (formerly Bowling Green, Ohio)
    <div class='quotetop'>QUOTE(prius biker @ Oct 2 2006, 05:49 PM) [snapback]327148[/snapback]</div>
    Same here in Bowling Green, Ohio... Similar sized towns, terrains, climate, etc... (FYI Fremont is about 28 miles east of Bowling Green in northwest Ohio, both are on US route 6)
    Im at around 10,100 miles and driving from Bowling Green to Port Clinton I can get up to 52 MPG with careful driving in summer weather... Routinely making trips from BG to Findlay and Back on I-75 I average 47-49 MPG on the highway at 60MPH (higher if I can draft a large truck, at a safe distance of course :))
  20. Tideland Prius
    16,534
    <div class='quotetop'>QUOTE(karat @ Oct 3 2006, 11:20 AM) [snapback]327408[/snapback]</div>
    Ok, that's a serious issue if the battery loses 2-3 bars overnight. Somewhere, there's a leak. Take it to the dealer asap and have them look at it. Let them keep the car overnight so that they can see that it drains from green to pink.
    Driving with the engine is more efficient than having it convert into stored energy in the battery then converted back again.
