Clattering noise from suspension
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pixelmixer, Aug 10, 2010.
  1. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    On the wild chance that someone here has had this symptom...
    Since new my Prius V has had a metallic clattering sound that comes from underneath the car. This can be replicated when driving over lane divider dots on a quiet street with the windows down. To investigate, I put the car on ramps and looked around; I was almost certain the sound was coming from a thin aluminum heat shield that is just behind the engine. Tapping this shield made a similar sound to what I heard coming from under the car while driving over bumps and such. The shield is poorly attached with those "fun" push pin fasteners that seem to be liberally deployed all over the undercarriage. I decided to re-attached the shield with a judicious circular application of silicone under each of the holes in the shield and let it dry. The clattering sound I heard previously when tapping the shield was gone. Out for a test drive and........still there!
    I just had the first service done, and of course the tech couldn't hear it on his test drive. Unfortunately I was pressed for time, so I wasn't able to take a test drive with the tech. I will drive the tech around next time and demonstrate it.
    Any ideas or experiences?
  2. gpt
    gpt Junior Member
    17
    Athens
    I hear the same from Day 1, but I have no idea where it comes from. I thought it is the suspension as well, and I am waiting my first visit to the dealer.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sounds like the brake calipers rattling. There is a TSB out for that. Just a guess though.
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Same here. When I hit a divider or bump, I get the usual rattling in what I think is the rear suspension area. Otherwise everything is normal and quiet. If it is the calipers I wonder what the fix would be? I would prefer to do it myself.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Apparently the dealers are placing shims in the calipers to tighten things up. I would suggest going to them for the work.
  6. pixelmixer
    102
    Seal Beach CA
    Thanks all for responding. It is interesting to read other's experiences. The sound isn't like "caliper" rattle, it's much more like a thin metal sound and seems to be located towards the front of the car.
  7. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I seem to have the same issue... but only after I swapped my stock 15s for the OEM 17s. Not sure if that had anything to do with it, but now I hear the clattering when going over speed bumps or Bott dots. The noise seems to be coming from the front suspension area.
    On a separate note, my parents owned a 2000 Toyota Camry, which had the same rattling issue from the front right suspension area. They took it to the dealer multiple times to have the tech look into it, only to be told multiple times that the tech couldn't find any issues with it....
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I had the exact same issue with my 97 Camry. Drove me nuts (short trip). I even went as far as to have the struts replaced. The only thing I didn't have done was have the brake pads replaced because even after 127K, they were fine. I suspect it was the calipers.
  9. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Thanks Spiderman! I'll check with the dealership.
  10. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  11. pixelmixer
    102
    Seal Beach CA
    Clattering noise from suspension-Update
    My friend just purchased a 2010 Prius, and as we compared notes I mentioned to him the "clattering" sound that I hear from under my 2010 Prius when driving over Botts dots and such. He related to me that he hears a noise from under his car when driving over the Botts dots as well. So we took a ride together and it is indeed the same sound that I hear. The interesting observation is that if while going over the dots you apply the brakes firmly, the "clattering" noise is no longer heard. This is intriguing given spiderman's post about brake caliper rattle. I have searched and cannot find a TSB database that includes any caliper service relating to this sound. The sound isn't subtle; it's very apparent and actually unsettling given 2 cars purchased within a few months make this annoying noise. I'll get it checked at my next service of course. Are there any posters aware of a specific TSB relating to this issue?
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Re: Clattering noise from suspension-Update
    Doing a quick search I found this.
    Though this is not exactly the problem, but it might fix it. I will try to find the PC thread related the the rattle.
  13. darenko
    darenko New Member
    Seattle
    I get the same noise from my car. I took it in for my oil change and told them to take a look and they could not reproduce the sound. I came to pick up my car and asked to go on a ride with a tech. After driving around I was able to get him to hear the noise but he was not sure where it coming from and said he needed it the whole day to diagnose it. I had to leave on vacation so I could not leave the car. I hear this dang noise everyday. I had the TSB stated above done on my car last year which fixed my brake noise, but this noise has been present for the last 12 thousand miles on the car.
    I get the noise from all sorts of scenarios (bumps, potholes, any sort of suspension compression in the front). I think it's coming from the brakes area and not the suspension. Anyway, I hope someone else can get this fixed because I spent 9 months trying to get my brake squeak fixed and it took a TSB to get it fixed (and even then I had to take it more than 3 times to get it fixed as the TSB I think had multiple solutions and they just tried one at a time. what a waste of my time).
  14. mmichaell
    mmichaell Member
    241
    chicago
    If it sounds non-metallic, it could be one of the many plastic panels under the car.
  15. Turkf26
    Turkf26 New prius owner
    Vacaville,ca
    I have the same sound and it is definetly a "clunk" from the front suspension. I work at a bodyshop here in Cali and have had multiple people drive and hear the sound. Of course the dealership cant figure out the problem but i have narrowed it down to the strut assembly. The only thing we can figure it may be is the spring compressing and rubbing on the upper and lower mounts. The rubber between the bottom of the spring and the strut housing is no where near what it should be to stop metal from metal contact. I am going to see if i can compress the strut and add some sort of addition to the rubber ring to see if that gets rid of the noise.
    Has anyone else tried this?
  16. pixelmixer
    102
    Seal Beach CA
    In my case after driving 2 nearly identical cars (2010 III and my 2010 V) the clattering noise goes away upon brake application. Based on the amount of responses to my original post, it sounds like an issue that many cars exhibit.
  17. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I hear this also...it makes me cringe every time because I can hear the sound echoing off the pavement from what is an otherwise quiet car. Glad to hear I'm not alone!
  18. techcar
    techcar Junior Member
    Westchester County
    how can I find the TSB myself? I have the same annoying noise and the dealer never hears anything...
    Thanks, and what foglite kit did you use?
    Thanks for the help.
    Techcar
  19. pixelmixer
    102
    Seal Beach CA
    Here is the latest update:
    Recently my friend had a Toyota Tech record the clattering sound coming from his 2010 Prius. If I understood correctly, it will be sent to Japan for review. In the meantime, the Tech installed something to attempt to quiet the clatter but it didn't work. He's now waiting for Toyota to come up with a fix, as this isn't the first time they've had a complaint about the noise. Also, it appears the front calipers are Corolla-sourced. Have to wait & see what Toyota and the Techs come up with.
    The dealership claims there is no TSB on this problem.
  20. Oakmont
    Oakmont New Member
    26
    Pittsburgh
