Clazzio Covers/REAR SEAT REMOVAL - HELP!:)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by unit333, Jan 23, 2010.
  1. unit333
    unit333 Junior Member
    77
    NYC
    Hey
    I got the Clazzio dark gray for my Prius 2010
    The front ones were fairly easy to install and look very nice. However I read from cover to cover each thread regarding how to remove the rear seat and how there are 2 pressure hooks underneath that you press, etc and yet I cannot even find them. I looked for 30 minutes, touched every inch multiple times and no luck. Can you guys give me a real simple explanation of the process, maybe even post a picture or two if you have it, so I can actually really visualize what we are talking about.
    Thank you!
  2. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    154
    Iceland
    You literally just put your hands under the seat and pull upwards. It will come right out.
  3. unit333
    77
    NYC
    I tried, still not working
  4. Boo
    Boo Boola Boola Member
    5,051
    475
    97
    Flushing, NY
    If the rear seat is like the Gen II, there are two hooks/clips in the front -- one in the middle of the passenger side seat and another in the middle of the driver side seat. You can unhook both hooks by lifting the seat up with your left arm on the left and your right arm on the right (alternatively, the Seat Assembly Instructions say to unhook each hook one at a time).
    Once you lift the front up you should be able to see and unhook another hook/clip in the center rear.
    Here are the Gen II Seat Assembly Instructions. Page 15 illustrates and describes how to remove the rear seat cushion:
    [​IMG] SE%20-%20Seat.pdf
  5. rrolff
    rrolff Prius Surgeon
    1,610
    243
    So Cal
    This is correct - you grab, and yank it up *hard*. It will unlatch. You may end up having to get a new plastic latch piece (it's probably 50/50 chance). They're like $4.
  6. Harry and Nancy
    Harry and Nancy New Member
    Big Bear, California
    Thank you all for help. This Forum is dynamite, no, it's a gold mine! Should've been here before we bought! Hindsight is 20/20.
  7. BNAL
    BNAL New Member
    Temecula, CA
    The only difference with the gen II and III is that there are 2 rear hooks. It does take effort to get the hooks free, but as long as you pull up there should be no damage to the clips.
    One thing a lot of people are having problems with is getting the front hooks to fasten when putting the seats back. I had the same issue, but today tried again, but this time I tilted the seat backs down about 45% and pulled up on the rear hook and down on the front. The front hook locked in place with little effort. I repeated the process on the other hook and the seat is locked in place.
    I hope this helps.
  8. us_matrix
    us_matrix Member
    110
    Does anyone know that if the Gen II rear seat hooks/clips postion same as Gen III. In the Gen II PDF doc from page 15. It shows two clips in front and one hook in the center rear? Same postion as Gen III?
    I am going to install Clazzio cover and want to find out where are the clips/hook located.
    Thanks.
  9. Steve23
    Steve23 New Member
    Guys,
    With the thread here I was able to easily remove the rear seat bottom but I had the same issue getting it snapped back in. I saw that the two front metal bar loops were supposed to snap back into the plastic receptacles and I used a plastic trim removal tool to pop the receptacles out of the metal bracket and then I popped them onto the seat loops with a rubber mallet. (This is with the seat bottom out and upside down). Then the seat snapped right back down no problem. (I was putting Wet Okole's on and they look fantastic) (Gen III 2011)
    Steve D
  10. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    2012 Prius REAR SEAT REMOVAL and REINSTALL - HELP!:) 3-2-2012
    Removal-
    Slide hand under the front of the rear seat approx. 1 foot in from the end. Using both hands, YANK up hard until the side comes up. Do the same for the other side. For best results, use 2 people: one on each side of the front edge of the seat bottom.
    Reinstalling-
    One item many people are having problems with is getting the front loop hooks to fasten when reinstalling the rear seat bottom. We had the same issue.
    Try: Tilt the rear seat backs forward approx 45 degrees so you can get your hand down to the rear loop hook. While facing the rear of the car, pull up on the rear loop hook and kneel down (using much pressure) on the front while gently moving from side to side. After a moment or so, you should hear a click indicating that the seat is installed. Then go to the other side and do the same. If this does not work, check to see if the plastic pins in the plastic receptacles are broken and/or try the below.
    Or
    Note: If replacement receptacles are need, they only cost approx. $5.00 each.
  11. chami
    chami New Member
    Mount Lavinia,Sri Lanka
    I am going to remove the rear set of mine pretty soon.
    Just want to be confirm a place on ebay or Amazon for a replacement of the 'plastic clips' just in case.
    Having trouble finding one though most have commented its just $4-$5.
    Can someone please tell me how to search ( A part no. ? ) or a link where I can find it.
    Thanks in advance.
  12. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    There's a few videos on Youtube. Just enter 2010+ Prius rear seat removal. Hope this helps.
  13. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
  14. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Thanks for posting the video Revhigh,
    My computer skills suck big-time.....lol!
  15. iskoos
    iskoos Active Member
    286
    194
    Orlando, FL
    When posting a video or PDF file that is part of a forum thread, the poster needs to make sure those files will be available to others all the time otherwise the thread will be useless. In this thread, both the video and the PDF files are not accessible anymore.
    ASRDogman likes this.
Loading...
