Clean leaves in front of the bottom radiator
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Peng Xiao, Dec 29, 2022.
  1. Peng Xiao
    Peng Xiao Junior Member
    83
    New Jersey
    2018 Prius Prime
    I opened the hood, looked through the hole that lock the hood, see some big leaves in front of the bottom radiator. Tried to use a handheld vacuum, but not long enough. And the hole is too small for floor vacuum tube. Anyone has experience to clean that area? Remove the panel under the car?
    I will try again from the front.
    #1 Peng Xiao, Dec 29, 2022
  2. Peng Xiao
    83
    New Jersey
    2018 Prius Prime
    That area is not easy to reach. I took off the panel from bottom, still some plastic under it. As it doesn’t block the radiator that much, I think I will just leave it.
  3. BiomedO1
    BiomedO1 Senior Member
    1,320
    722
    SacTown, Ca
    You should be able to get down there by removing that plastic tray around the hood release mechanism. I believe its only held down by a bunch of plastic anchor pins. Pop the center pins up & remove the pins. Replace in reverse order.
    Hope this helps..
  4. Mendel Leisk
    38,239
    Or take the frontmost under-panel off? You might be able to do without any lift, or just up on low rise lifts, say a couple of layers of 2x8. Then they’re right there, might just fall out.
  5. Peng Xiao
    83
    New Jersey
    2018 Prius Prime
    No, another plastic above the under-panel.
  6. Peng Xiao
    83
    New Jersey
    2018 Prius Prime
    Did what you said, cleaned almost all, except under the radiator, I think.
