Clean way to tap into VSS?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Azimuth, May 29, 2010.
  1. Azimuth
    Azimuth Member
    136
    32
    Austin
    Has anyone found a clean way to tap into the 20-pin connector that has the VSS wire and steering wheel controls on it?
    I used T-Splice connectors on the PAC-SWI cables which was extremely tight, I'm not sure if I can fit another T connector on those wires. not to mention the wires are ultra fine and I'm always worried I'll break them.
    additionally, I hear that the VSS signal has to be very clean since it has a lot of variation in current which is what the NAV unit measures. I'm not sure a splice will achieve a high enough quality connection.
    I'd love to find a male connector that fits on that 20-pin harness.
    Anyway, I'd be thankful of any ideas.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
  3. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    It would be really nice to find a Molex plug and/or harness, so we can solder instead of splice. If anybody finds a source, please post it.
