Cleaned intake manifold and EGR pipe and it truly feels smoother!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 5 Speed, Sep 19, 2017.
  1. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    I spent a few hours removing and cleaning my intake manifold and EGR pipe and while I was at it replaced the PCV valve and I truly feels like the engine is smoother and so far gained about 1MPG in the last 100 miles. I know that this isn't scientific but I swear the engine is smoother and the MPG slightly better. There was a considerable pool of oil right below the throttle body and it was dirty throughout the whole intake. I used about two cans of brake cleaner to clean out all the gunk inside the manifold, EGR pipe and cleaned up the throttle body with carb cleaner when I had it off. I replaced the PCV valve and the manifold gasket. With a Prius with 150K I figured it was time. The
    Nutz About Bolts videos are so helpful!!!! Thank you!
  2. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I'm doing the same exact thing right now, nutzaboutbolts is a godsend. I'm going to upload some pics.
    NutzAboutBolts and Raytheeagle like this.
  3. Mendel Leisk
    38,726
    Yeah I've just cleaned ours, the intake manifold, same story: lots of oil, and grungy bits in the EGR passages. The MAP sensor (below throttle body was just SOAKED in oil. I removed it and cleaned by dipping in isopropyl alcohol, hopefully that's compatible, seems ok. Only 70K km's, but that oil was in there quite some time back, I noticed when doing an in situ throttle body clean, some time back.
    I just carefully peeled off all gaskets, and reused. And did not disconnect throttle body coolant lines, just unbolted and lifted out of the way.
    Also, installed an Oil Catch Can, between PCV valve and intake manifold. I'm hoping this will stop a return of the oil, time will tell.
    I'm going to take on the EGR valve and cooler very soon, have a few necessary items coming.
    And yeah: kudos to @NutzAboutBolts for the videos.
  4. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    Going to do the EGR valve and cooler this weekend, needed to get the tool to remove the studs and could not do it without the @NutzAboutBolts videos!!!
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    You could do it without the videos, but life is challenging enough;).
    The E8 torx socket and ratcheting wrenches are invaluable for the job:). As someone whose done the job 3 times, you learn something each time you do it;).
    Good luck this weekend(y)
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    What a savage! Now you're just abusing the EGR and it doesn't like you touching it :ROFLMAO::ROFLMAO::ROFLMAO:
    Raytheeagle likes this.
  7. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    The egr system was on 3 different Prii ;).
    But each time I do the work, I make sure to talk nicely to the ingoing system:whistle:.
    Maybe @mmmodem will decide his is up next(y).
    NutzAboutBolts likes this.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    HAHAHA, maybe on a cold day in November. :sneaky:
  9. Mendel Leisk
    38,726
    @Raytheeagle you may not be an abuser but you are obviously a masochist, to take that on more than once, lol.
    scona, NutzAboutBolts and Raytheeagle like this.
  10. Dan05979
    Dan05979 Member
    181
    101
    I want to upload some pics from my recent work, but everytime i share the image code from photobucket it's not showing on a "preview thread"
  11. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Each time there has been more than just me;).
    If it were just me, I'd agree. You want a real challenge, try swapping the cooler and valve with the windshield wiper cowling on. That can be real fiddly:whistle:.
    Good luck with your clean and replace work:). Can't wait to see what a low mileage system looks like(y).
    m.wynn, Mendel Leisk and SFO like this.
  12. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    So I should clean @Rebound 's cooler sooner rather than later then:).
    It'll be clean and ready when you are(y).
  13. NutzAboutBolts
    1,476
    1,552
    Bay Area
    You just like to clean everyone's dirty pipe huh? Lol jp
    The more you do, the more experience you learn :)
  14. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    When you have 2 kids and live 5 doors down from your inlaws, sometimes an excuse to be out in the garage is welcome;).
    But learning is something that is a nice side benefit(y).
    #14 Raytheeagle, Sep 20, 2017
  15. Dan05979
    Dan05979 Member
    181
    101
    Hey NUTZ, I want to thank you very much for your videos. So far I have changed my oil, transmission fluid, doing the whole EGR intake thing at the moment. I wish there was a person like you who also does F10 BMW 5 series in depth like you so I can save some big $$ on mine.
  16. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I soon will be in that predicament, but I don't know if I will have time to do any work in the garage. lol
  17. NutzAboutBolts
    1,476
    1,552
    Bay Area
    good work!
    I wish I could afford a BMW lol...
    Dan05979 likes this.
  18. Mendel Leisk
    38,726
    I can get a 12 mm long socket plus extension on that hidden lower EGR nut, after a lot of strife, but so far getting a ratchet wrench locked on the end, or preassembling the whole thing and fishing it in there, nope.
    Just practice, and I packed it in for the night. I'm hoping it's slightly easier with the cowl off.
    Oh and my hands look almost as bad as @StarCaller's now. :oops:
  19. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Keep practicing ;). The ratcheting wrench is particularly handy for the lower rear nut on the cooler. An actual ratchet there will try your patience:(.
    But patience is a virtue (y).
  20. Mendel Leisk
    38,726
    Managed it. Cracked it slightly looser for now. :)
