Cleaning around the emblems
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ZPriusv5, Aug 26, 2012.
  1. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    Anyone have any techniques or tools for cleaning in the nooks and crannies of the "PriusV" or "HYBRID" emblems on the back and front quarter panels?
    My v is only a few weeks old but I can already tell those spots will collect road grime. Q-tips don't seems sturdy enough once they get wet.
  2. Snoopytoo
    Snoopytoo Junior Member
    Toronto, Canada
    Try an old toothbrush. Has always worked for me
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    Removing them makes the car look nicer and easier to keep clean... Some emblems have holes in the metal behind them, others are just attached with putty... Do a search on here for the term debadge or de-badge to learn which ones you can remove...
    Another option is to create stickers to replace your badges with, which will eliminate the nooks and crannies that are hard to reach.
    Note: High-priced car detailers used to remove all the badges before polishing and waxing, but with the kind of adhesive putty Toyota uses these days that might take more time than it's worth...
  4. egeorge1
    egeorge1 Eric
    46
    San Antonio, Texas
    FYI, All the emblems on the v are bolt on.
  5. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    All the Prius v emblems are held on with double side 3m adhesive, but have locating pins on them, so holes are revealed on the body when removed. No bolts are used.
