Cleaning Blower fan. Lubricant recommended?
Discussion in 'Gen 2 Prius Main Forum' started by George W, Apr 7, 2019.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    When cleaning the Blower fan, is their any benefit to adding a graphite or silicone Lubricant to reduce spindle friction? Thanks.
  2. T1 Terry
    T1 Terry Active Member
    929
    478
    I replaced mine with a second hand one from a vehicle wrecker. The old unit didn't come apart really well and was very worn in bronze bushes so replace was an easier option to repair. I did soak the felt pads in the bronze bushes with some motor oil before fitting the replacement unit and that seems to have been good enough, virtually silent at lower speeds rather than sounding like it was trying to escape and attack via the vents :lol:
    T1 Terry
  3. 09Prius2
    09Prius2 Member
    201
    88
    FL
    The friction comes from the impeller wheel outside. Eventually it starts rubbing the housing and making noise due to contact.
    Its not really a serviceable unit and they are fairly inexpensive to buy. If you were going to lubricate a motor spindle you would probably want to use a 3 in one drip oil, but in this case I don't see it really doing anything.
  4. George W
    911
    514
    San Antonio
    Thank you for your responses. I wasn't sure if a dry or a wet lubricant would be applicable, since either could collect foreign particles thru adhesion or static.
