Cleaning EGR valve and cooler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yeldogt, Aug 10, 2018.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    $1250 later the 2011 w/214k is back. New EGR valve and cooler/ intake cleaned -- new plugs and PVC.
    I had a new OE valve so he did not try and clean -- but the attempt to clean the cooler was not successful. It's completely clogged -- if you fill it with cleaner it will slowly drain. Very slowly. Reading up on this it seems most like to use carb cleaner -- I'm thinking of filling it up, plugging the ends and putting it in a bag for a while. Has anyone attempted doing a totally clogged one?
    Also -- should I even attempt to clean the EGR ?
    Reason: we have other Prius and out Lexus CT's have the same engine -- So having a clean cooler would be a benefit .. EGR as well
  2. working1
    working1 Active Member
    121
    112
    Oxiclean is highly rated. Soak in very hot cleaning solution overnight. Rinse with very hot water. Best to have a utility sink to force water into one end. Repeat multiple times. It took at least 13 soakings with the one I cleaned over a number of days. It can be done, just not quickly.
  3. Luckykat32
    Luckykat32 Junior Member
    22
    So Cal
    Mine took several soakings in about 3 or 4 days and I was well over 200,000 miles. What really clean it for me is I took a hanger and jammed it through all of the holes in the EGR cooler period that took me about 30 or 40 minutes and then you could see light through it.
    There's several people on here that will trade you there clean one for your used one if you just start asking around
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I’ve done the plugged cooler job with carb cleaner;).
    Seems to work ok, but I hit it with the pressure washer and it got it spic and span clean:).
    $1250 though:eek:.
    Why not buy used from a salvage yard:whistle:?
    Having a clean spare is worthwhile(y).
    #4 Raytheeagle, Aug 10, 2018
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would keep the old one and clean it
  6. yeldogt
    810
    313
    NE
    The parts -- even from online dealers -- are pushing $600. Many hours of labor to replace the valve/cooler and to RR and clean the intake.
    My hope was to clean this cooler and have it available to switch out in another car .. not sure how the EGR is cleaned or tested.
  7. Troels
    Troels Junior Member
    29
    16
    Sacramento
    I have the EGR valve out, is there a way to physically check if it is stuck? It passed the electrical resistance test found in the repair manual, but I would like to make sure its not stuck. Thanks!
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Take the black cap off and actuate the plunger;).
    That’s the one way to do it(y).
    Troels likes this.
  9. ASRDogman
    ASRDogman Senior Member
    7,799
    3,978
    Oven cleaner and Gunk, the flammable gunk. Pressure washer helps, YOU WILL GET WET! :)
  10. Troels
    29
    16
    Sacramento
    Thanks, that worked!
  11. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Try setting the cooler in or against something;).
    I have an old metal lawn chair that I used and avoided any wetness or soiling:).
    Worked well(y).
  12. ASRDogman
    7,799
    3,978
    It's just water. And you MUST hold it, unless you tie it to something.
    Orrrrrr, have someone hold it for you! :)
  13. Troels
    29
    16
    Sacramento
    Ditto on the hanger.
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    So the metal chair had slots and you wedge it in. That holds it in place;).
    Nothing fancy required and you hose the chair down afterwards :).
    The wife was none the wiser(y).
