Cleaning fuel injectors
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ef817, Dec 24, 2017.
  1. ef817
    ef817 Junior Member
    2013 Prius v wagon
    I keep getting reminders from my dealer that I need to have my fuel injectors cleaned. Is this something that actually helps or is it just a way for them to stick me for an extra repair bill?
  2. Mendel Leisk
    40,574
    Email reminders? Look for unsubscribe button. And yes: just snake oil.
    m.wynn likes this.
  3. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    Save your money...unnecessary service on a Prius.
    Will not increase MPG.
    No benefit if vehicle is running smoothly.
    Will not necessary prolong the life of the metals and plastic used in the F.I. component system.
    If vehicle has a rough/ lump idle then you can look to a fuel inj. issue and clean or replace.
    If a performance vehicle, even new injectors, can have their spray pattern optimized; not necessary in a Prius.
    If you wish to keep your fuel system clean and also help with carbon build up in the combustion chamber, use top tier fuels only and add some Techron (or like product) through the fuel tank and then change the motor oil and filter to flush out the residue the Techron loosened.....IMO.
    I am with Mendel above...dealer snake oil.
  4. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    May or may not (slightly) improve your injector function. Definitely lightens your wallet.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Find a new dealer.
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,589
    5,888
    Texas Hill Country
    These days most name brand gasoline has enough fuel injection additives already. It used to be recommended prior to almost universal use of additives which, for the most part, were included because of the widespread use of fuel injectors. Mass air flow sensors and throttle bodies sometimes need cleaning.
    dubit likes this.
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Believe it or not, they may not even know they are sending it out. Comes as a "complimentary" service to the dealer when they purchase things from say "reynolds & reynolds" or some other company. (They access your customer list, and send these "complimentary emails" as a service to you the dealer to help bring in additional service income.)
    Just hit the unsubscribe link - easiest thing you can do there.
    Raytheeagle likes this.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Good advice, mostly.
    I give all my vehicles an appropriate dose of Techron at each oil change .....myself.
    Highly unlikely that anything that the fuel treatment "removes" will end up in the crankcase though.
    No need for an extra oil change.
    But if you are REALLY worried about that part, do the Techron treatment one tankful BEFORE your scheduled oil change.
    Oh, and yes the dealer's recommendation for injector cleaning is mostly unnecessary and/or way overpriced.
  9. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Or just buy Texaco or Chevron gas and get Techron in every tank.
  10. mikefocke
    3,899
    1,755
    Sanford, NC
    Then please explain how oil gets dirty? Might it be combustion byproducts that blow by the rings and enter the crankcase.
    So if the dissolved deposits and the chemicals that are solvents to those deposits are likewise able to bypass the rings' sealing with the cylinder walls, do you really want that gunk and those solvents (the enemy of oil) in your oil for the next 5k miles?
    I'm for using Techron every 30k or so miles two tanks run low before an oil change especially if you are running that oil change the intervals most manufacturers now suggest.
    Remember most gas has those solvents already but in much smaller dilutions.
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    The suggestion of changing the oil immediately after a dose of carb or injector cleaner pre-supposes that:
    1) There is a large quantity of deposits that will be removed and 2) That a significant percentage of what is loosened will get past the rings.
    Neither is true......in most cases.
    The "Dirt" that gets into the oil happens over THOUSANDS of miles and part of it is the components of the oil itself breaking down.
  12. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    How many miles do you have on this vehicle now?
  13. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    ...breaking down, and the wear and tears on those metal components too.
  14. cdnbrit
    cdnbrit Junior Member
    57
    24
    Cambridge, Ontario
    2018 Prius Prime
    Upgrade
    I bought the Toyota Brand Fuel Injector Cleaner. my car didn't seem any different after using it.. Grats Toyota you win again!!
  15. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    If you want to clean carbs or injectors, use sea foam. Sea foam cleans and stabilizes fuel and removes any water/moisture in the fuel.
    Z917VL ?
  16. Sam Spade
    2,036
    1,023
    2017 Prius c
    Which really is re-branded Techron at twice the price.....or more.
    cdnbrit likes this.
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    Here we go again. Another "convert" to the SeaFoam snake oil marketing hype.
    The company that sells the stuff does not even call itself a chemical company or an automotive company; the name is "SeaFoam Sales".
    They are really good at sales. Their product is a jack of all trades and master of none.
    If you want a really good carb, injector or fuel system cleaner......use Berrymans B12 Chemtool or Gumout. All others are wanna bees.
    Techron is good for injector maintenance but B12 and Gumout are better heavy duty cleaners.
    cdnbrit likes this.
