Cleaning hatch window edge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Oona, Dec 9, 2016.
  1. Oona
    Oona New Member
    Pacific time zone
    I have to park my 2015 prius under a tree that drops tiny leaves and seeds on it that are working their way under the edge of the hatchback glass and also under the mini spoiler. How do I get that out?
  2. saltdiscus
    saltdiscus Member
    198
    89
    US
    Yes got same problem for 2014 Prius.I used small hose vaccum and clean 89 percent of these leaves and dirt.
    51,141
    welcome! that's about all you can do. try sliding a thin blade in there or other sharp object as you vac. or cover it while parked.
  4. Mendel Leisk
    40,574
    Some areas you might be able to "floss" with some twine. It's too bad the spoiler is not easily removable.
    I've got the same problem btw: pine needles and the like are bad.
  5. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    Specific detailing brushes.
    Plastic picks.
    Plastic "bondo" spreaders.
    Edge of micro fiber cloth in tandem with above.
    Yes good advice to vacuum as much debris out as you can before using the above.
    Once cleaned go heavy with a wax to aid in the next cleaning.
    That's my two cent comment
  6. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Compressed air. If you have a compressor, use that. Otherwise a cheap can of air (used to blow dust out of computer equipment) might do the trick.
    saltdiscus likes this.
