Cleaning out Engine Air Intake
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Feb 25, 2014.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,573
    Iowa
    This came up in one of my endless threads about mice woes.
    Anyway, Patrick Wong suggested I clear the intake tunnel and I thought why not do this on a maintenance basis for all cars?
    Any reason why not?
    Not too tough to do....Here is Patrick's suggestion (which, once again, he made in specific response to my mouse problem):
    I'd like to propose a labor-saving alternative to my earlier suggestion of accessing the air resonator chamber located in the front passenger wheel well. Instead, disconnect the air duct that leads to the engine air filter housing, and attach that to a shop vacuum hose, using packaging tape for a good seal. Turn on the vacuum and see what is sucked up.
    Then, attach the vacuum hose to the shop vacuum exhaust, and blow air back into the air duct. See what comes out of the air inlet which faces towards the windshield washer reservoir. Make sure you have an unimpeded flow of air before you declare victory.
  2. Gerry Hartzell
    Gerry Hartzell New Member
    Lowerlake,Ca.
    I have not been able to blow out or suck out what is totally blocking my air intake assembly. I've tried from inlet and outlet. Can any one tell me how to remove the portion below the headlight. "Please"
  3. Patrick Wong
    18,200
    6,472
    You probably would need to jack up the right front corner of the car, support that corner with a jackstand, remove the tire, then remove the plastic fender liner for access to the intake air resonator.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Why do you think there’s something blocking the intake?
    Prodigyplace likes this.
