Cleaning Radar SENSORS
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Zardoz, Feb 9, 2018.
  1. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    The manual says to both clean the emblem AND ALL radar sensors.
    How the heck do I gain access to the radar sensors to clean them and HOW do I clean them?
    I cannot find this tidbit in the manual.
    Thanks!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Just the emblem - and the windscreen
    kithmo likes this.
  3. Tideland Prius
    16,623
    Well the manual does say "clean with a soft cloth".
    The front one is somewhat easy to get to - just open the hood.
    I'm not sure how you'd access the BSM/RCTA radar sensors. I would hope they're better sealed.
    pilotgrrl, RCO and Prodigyplace like this.
  4. RRxing
    RRxing Senior Member
    2,555
    1,828
    NEPA
    I think it's just referring to the outer (visible) surfaces...
    pilotgrrl and RCO like this.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Your blind spot detection sensors are the little round thingies located on the rear bumper and the sides, and the close proximity sensors are also the little round thingies located on the front bumper and on the sides and on the rear bumper, so, clean the toyota emblem front center on the bumper, and clean all the little round thingies, the rear ones get covered with snow if you drive in the snow, they don't signal an alarm untill you stop and restart, then you get an exclamation symbol on the dash, clean them and the dash warning goes away.
    pilotgrrl, RCO, walterm and 1 other person like this.
  6. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Although one might like to put a light coating of RainX or wax on the emblem, sensor areas, or windshield so they don't get easily spooged, I suspect that is not a truly wonderful idea.
    RCO likes this.
  7. alanclarkeau
    7,045
    7,593
    I think they suggest not putting anything on - if anything I'd use a non-silicone wax, as it will come off easily. RainX won't come off.
    RCO and pilotgrrl like this.
  8. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I was thinking that the Blind Spot Detection Sensors were separate and distinct from the round thingies — that is to say they are invisible from outside of the car.
    On several occasions I have has the parking sensors ice up and received the failure warning, but — if memory serves — the BSM still worked.
    RCO likes this.
  9. Tideland Prius
    16,623
    That's correct. ICS and BSM/RCTA are two different entities. BSM/RCTA use radars mounted behind the rear bumper. The sonar sensors that are visible on the bumper are ICS (well 8 of them are for ICS, 4 are for IPA)
    RCO likes this.
  10. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    And, you will note that the manual tells us to CLEAN the sensor that is behind the bumper...
  11. alanclarkeau
    7,045
    7,593
    I see that in the manual - but how? I had a look the other day - I can't get my hand in there.
  12. Tideland Prius
    16,623
    It's fine. I've never cleaned the radar sensor behind the bumper on mine and I've driven in dust, mud and snow (Prairie living for ya).
    Just the emblem is enough for me (and even then, I've never seen the "CLEAN RADAR" message - the Gen 3 system is different from the Gen 4 Prius though... I've noticed you guys have reported seeing it more often so Toyota must've changed the parameters)
    RCO and alanclarkeau like this.
  13. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    It happened to me twice this winter : ICS Not availabe with a message asking me to clean the sensors ... went outside , the emblem is clean , all the proximity sensors is clean .. i had no idea why but it went away eventually.
    It happened again this morning but this time i noticed something : A bit of fog or condensation inside of the housing of the camera behind the rear view mirror - now things add up in my head , i remember to have used the front defroster both times then this must surely magnify the condensation problem. .. this camera housing needs to be sealed and its part of the ICS, Correct ? i will have that checked by the dealer when ill bring in my car in to swap my winter tires.
    RCO likes this.
  14. ALI SAJJAD
    ALI SAJJAD New Member
    LAHORE PAKISTAN
    I have problem clean radar sensor and also showing massage pre crash error again and again, what do you guid me ,
