Cleaning the Clear Plastic Cover over the Speedo Display
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, Sep 11, 2007.
  1. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    Hi. I have some water spots on the clear plastic speedometer cover. What's best to clean it?
    I use an LCD cleaner to clean the MFD, but I don't want to use it on the clear plastic because I think it leaves a protective coating.
    So what do you use to clean the speedo cover?
    Thanks - Marvin
  2. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    Distilled water and a soft cloth. DO NOT RUB. DO NOT USE EXCESS WATER. Wring all the water you can out of the cloth before you use it. If any drops fall down to the mirror, you will be unable to clean them up. The water will dissolve the water spots.
    I find a "Swiffer" duster works well to remove dust on the dash components. No chance of scratching, quick cleanup, no chance of stains as with a liquid cleaner.
  3. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    I use compressed air to clean the dust off the dashboard and air vents. Be careful of "cleaners" they can contain chemicals that can fog plastic. Good'ol damp cloth, finished off with a dry lint free cloth.
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Marvinh @ Sep 11 2007, 01:17 PM) [snapback]510770[/snapback]</div>
    Are you sure it is the cover which is spotted and not the mirror which reflects the image?
  5. IsrAmeriPrius
    4,333
    Southern California
  6. Godiva
    Godiva AmeriKan Citizen
    10,339
    I leave it alone.
  7. Godiva
    10,339
    I leave it alone.
  8. richard schumacher
    7,663
    1,039
    United States
    Windex and old well-washed cotton rags work for me.
  9. richard schumacher
    7,663
    1,039
    United States
  10. PriusVancouver
    PriusVancouver Junior Member
    FYI - Not for cleaning, but fixing fogged or heavily scratched surfaces, the local dealership told me you can use a plastic polish (I believe a brand is PlastiX). They also mentioned that this is now used on the headlights if they have become fogged over time due to small scratches from car washes etc.
  11. patmagee
    patmagee Junior Member
    The product I use to clean/polish my plastics with is called Plexus. I use it on the windshield of my bike as well as car light covers, speedo display and the MFD. Once applied, it resists additional stains and is anti-static.
  12. tah
    tah Junior Member
    Richmond, VA
    Mine looks dirty on the inside surfaces (mirror maybe?)......
    Any way to get inside and clean all surfaces?
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Kimtech wipes & Roscoe lens cleaner. They same stuff used on Pro Video camera len's.
    I also use that on the MFD touch panel.
