Cleaning the electronics / circuit board fixed my key fob
Discussion in 'Gen 2 Prius Audio and Electronics' started by treed678, Jul 4, 2017.
  1. treed678
    treed678 Junior Member
    Was frustrated last week when my remote quit working. I replaced the battery, showing 3 volts, with a new one, 3.2 volts and no change. Re-programming had no effect either. Would never get the "confirmed" lock/unlock in the final step.
    Started pricing replacements, minimum $55 (Amazon & eBay) WITH the electronics [don't be confused or misled by shell/case only items! $10-30 range]. Then I thought, what the heck... "let me just brush it off with a toothbrush and see what happens. It'll take 10 minutes ...better than just forking over $55 and waiting for a replacement." Well... it worked! No re-programming necessary. Thought this might be useful for anyone in the same situation.
    ZFL and bisco like this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    It may not work for long.
    Isopropyl alcohol and a Q-tip work better......followed by a thorough drying before putting the battery back in should produce results that will last longer.
    ZFL likes this.
    49,504
    i don't know anything about pc boards. what is happening that 'cleaning' helps?
  4. Sam Spade
    2,036
    1,023
    2017 Prius c
    Many remotes become contaminated from the oil on your finger tips.
    Yes, over time it will migrate from one side of that rubber membrane to the other side.
    But there are other things, including wear of the contact points and even maybe a bit of contamination left over from when they were made.
  5. bisco
    49,504
    thanks, and alcohol will clean all this up?
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Alcohol makes a lot of things better.
    ZFL, garglo and bisco like this.
  7. Sam Spade
    2,036
    1,023
    2017 Prius c
    Often yes.
    Until it gets TOO bad.
