cleaning the engine, and keeping it clean-how do I?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Sep 19, 2014.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    So I'm a first-time Prius owner, bought from a private sale about a month ago and love the car, but am realizing that due to some front end damage that happened before I bought the car, there are several pieces missing such as various kinds of splashguards, the wheel-well liners, the radiator support ("engine cover") and an underbody piece or two. I'm in the process of trying to identify all of these parts as well as track them down online, buy them, and install them before the winter.
    Now about the engine cleaning part: My engine is quite dusty, I think because my hood doesn't close like it should; I'm planning to adjust it, and also install the rubber seal thingy that's on the hood near the front. This should keep some of the junk out, hopefully.
    Now for the question!
    How do I clean the engine of the dust that's accumulated, and are those missing splash shields/engine covers above and below the engine the reason it's so dusty in there, or is it more likely the hood gap? (again, front-end damage and cheap nice person repair job by previous owner. )
  2. JC91006
    16,674
    8,519
    To answer just your question, you can just get a wet rag and wipe the engine clean. It may take you 15-30 minutes but it's the safest way to get the dust out of the engine compartment.
    #2 JC91006, Sep 19, 2014
    The Electric Me likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Most of the dust seams to enter through the front grill and radiators. The seal across the hood and the plastic rad cover also play a part in this.
    The bottom covers appear to be more to do with airflow under the car.
    One thing I would make sure of if there was front end damage is does the AC work and do the radiator fans blow towards the engine from the front grill, and not in the reverse blowing out of the grill. This is not at all uncommon with front end repairs. The problem being the two fans rotate in opposite directions, and if the blades are replaced on the wrong side of the car they blow in the wrong direction. This usually shows up as a high external air temperature on the MFD with the AC on, and the AC getting warm at 40 to 50 MPH. This will also draw dust up from the road surface acting like a vacuum cleaner.
    John (Britprius)
  4. Mendel Leisk
    40,586
    There's a thread going right now about an AC compressor connection that's corroded right out, will likely necessitate compressor replacement. That's one reason to not use water. Anyway:
    I'll vacuum what I can reach with a wet-dry, then switch it to blow. A leaf blower, or some source of compressed air is also good. An old paint brush will help. Also one of those duster on a stick: you can run it in between components.
  5. bmparent
    bmparent Member
    159
    65
    barre ma
    the prev. owner was lucky to escape any radiator damage, to my knowledge. I have used the AC, and it seems to work fine. I don't understand the part about the MFD and the external temp?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    That and if the bottom cover is missing below the condenser the ac condenser will take a real beating from road debris. It gets kicked right into the condenser which sits in front of the radiator. New condenser could be $1500 installed.
  7. Britprius
    5,194
    1,918
    The display on the center of the dash is called the MFD (multi function display), and it displays outside air temperature actually from just inside the front grill. When the fans are reversed they blow warm air from the rads over the sensor giving a false high temperature reading.
    John (Britprius)
  8. Fifine
    Fifine Member
    106
    So Cal
    Another variation is an old paint brush to loosen dirt/various residues, a spray bottle (with only warm water or very diluted Formula 409 for degreasing) and rags to wipe.
    Here in dense city life, it's a losing battle. The darn thing collects dust with dedicated regularity!
    Dealer has special offer of $199- to steam clean :sick:
  9. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    I cleaned my engine/engine bay using Purple Power in a spray bottle and rinsing with a light pressure hose. I did stay away from the inverter and all Orange wires. It was very dirty and it looked near showroom new when complete.
    bmparent likes this.
  10. Mendel Leisk
    40,586
  11. bmparent
    bmparent Member
    159
    65
    barre ma
    I think I'll stick with a damp cloth, and maybe a duster/brush of some kind. I sprayed my Nissan after I left the oil cap off once, it wasn't the same after that, don't know why. Could have been the spillage, could 've been the water.
