Clear coat peeling and wanted to how fix at home?
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Jun 13, 2020.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    307
    242
    Los Angeles
    I've seen youtube videos on fixing clearcoat and wanted to know anyone had done it and consider that it turned out good or bad?
    She's my work horse and I want to keep her pretty. Plus my Prius has that metallic seabreeze blue and I think this color is hard on clearcoat because the really beats down on this paint. 20200209_115808.jpg
    SM-J737T1 ?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,780
    2017 Prius c
    How much time and/or money are you willing to spend to do that ?
    I think there is a 50/50 chance that anything you try to do that is more complicated than a little light buffing to remove the loose material will end up making it look WORSE instead of better.
    I suggest that you first ask an independent body shop or two......to get a feel for what the professionals will suggest.
    Then.....how long before you think you might be ready to trade her in ??
  3. PriusRay128
    PriusRay128 Junior Member
    CALI
    If its just dull, you can just have a body shop lightly sand it and spray clear coat only and it will shine right up. If its already faded, its too late. I did that to my silver camry before it was too late and became like factory new!!! Whole process took under a hour
