Clearing windows and warming up in winter months.
Discussion in 'Gen 2 Prius Main Forum' started by LC598, Apr 1, 2011.
  1. LC598
    LC598 New Member
    Cambridge, UK
    We are going to look at two cars tomorrow. A 2004 and 2005 Prius. This may be a silly question but in the winter months my partner starts his car and lets it warm up and gets the windows cleared of mist. How do you so this with a Prius if only the electric and not the petrol engine comes on on start up?
  2. hadone
    hadone Junior Member
    Iowa
    When it is cold outside the ICE engine will start after a few seconds, that really defeats the idea behind a Prius. :(
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Maybe you could put a small electric heater on a timer in your car and set it to come on a hr. before you leave? They used to sell these at one time! Hal
  4. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    When you start a Prius and turn on the heat/windshield defogger the ICE (internal combustion engine) will run until it is warmed up, and then will run more often than when you're not calling for heat to keep the cabin warm. That's one reason Priuses get worse mileage in winter, the engine runs much more to generate cabin heat.
  5. LC598
    LC598 New Member
    Cambridge, UK
    Thanks for this. I'm still learning about all the features that they have. I guess will get easier if we actually take the plunge and buy one tomorrow.
  6. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Living in a temperate climate means you won't have to use the climate control as much or as strongly as other people.* So, you won't have as much of a hit as other people.
    Combine that with living in a flat area and you are really onto a winner.
    * We're expecting up to 14 inches of snow today. Over 6 have already fallen. No, your winter wasn't cold. ;)
  7. LC598
    LC598 New Member
    Cambridge, UK
    No, our winter wasn't that cold :) We had a little snow and our main issue is ice. I couldn't cope with that much snow!!
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    When defrosting any car initially, always put it on max defrost, outside air and only a slightly warmer temperature. Later after 5-10 minutes you can raise the temp and go to recirculated inside air, however if you adjust the heat too high and now have it on floor, then the windshield may begin rapidly accumulating moisture to the point of limited or NO windshield (windscreen) visibility. Seriously it can happen! Happened to me twice in Hawaii. So outside temperature is not the criteria, it is the local dew point on your windshield. That is the temperature differential between the outside and the inside of the windshield. In an emergency, open your windows immediately. The Prius also conforms to these rules. Cheers :cheer2:
    Benwhite likes this.
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I use rubbing alcohol in a spritz bottle so I don't scrape. I've used 70% & 90%. Buy the highest concentration you can find.
