"Click/clunk" sound when I hit the gas after letting go... what is the source of this noise?
Discussion in 'Gen 2 Prius Main Forum' started by SRQ, Nov 22, 2022.
  1. SRQ
    SRQ Member
    149
    53
    So when I let go of the gas, and hit the gas again, I can hear a "click/clunk" noise as power goes to the wheels. Sounds like it's coming from the front. Anyone experience something similar and find out what it was? Or is this too vague?
    48,943
    might be a cv joint, idk
    Tim Jones likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Or transmission problems.
    Is it shifting through all of the gears ok? : )
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    I always assumed that it was a contactor (big relay) opening or closing when going from regen to power to the wheels.
    You do know that it doesn't HAVE "gears" like a conventional transmission........right ??
  5. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Just checking......... : )
  6. dolj
    dolj Senior Member
    7,483
    3,763
    Wellington, New Zealand
    It pays not to assume. No relays involved in OP's post. I'm not really even sure of what you're thinking relay-wise. I would take a look at the lower engine mount.
  7. sam spade 2
    7,035
    2,782
    2017 Prius c
    It might depend on how sensitive your hearing IS.......and what you consider "abnormal".
    My C has done that occasionally since new; both of them actually.
    But the noise I hear/feel might not be the same as what he is asking about.
    Regardless of what kind of drive train you are dealing with, there should be some "slack" in the drive mechanism.
    Going from engine braking to engine power might make a noise in any vehicle........if you catch it just right.
    Some assumptions end up being right........and some wrong.
