clicking/grunting noise after cold start, intermittent
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stedman98, Nov 19, 2009.
  1. stedman98
    stedman98 New Member
    Virginia
    Occasionally when I start up Prius in the morning or after work, while the brake i depressed, I am getting a clicking/grunting sound (sounds like a series of short, fast grunts, actually) from under the dash on the passenger's side. It also happens when I have been driving awhile, when stopped at a traffic light, again with the brake depressed. It will go weeks with no noise, then do it several times in a day. HELP! Dealer is clueless because we can't replicate it. I have had the Prius over a year, and it is not one of the usual pump noises that I am accustomed to. I am going on a trip soon, and would like to have this resolved. I purchases Prius in Mississippi, but recently moved to Northern Virginia. Any ideas, you gurus out there?
    Thanks in advance!
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Mine does that as well. It sounds a little more like a faint honking noise, and you also only hear it while sitting at a stop light. Mine has been doing it now for over 2 years now (40,000 miles). It seems to be most frequent at about 30 - 40 degrees farenheit. If it is above 60 degrees it is rare that it happens. I've grown used to it. When I hit 100,000 miles I'll have the brake lines flushed and bled.
