Clicking Noise at 12-13mph
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Mar 22, 2018.
  1. stevepea
    stevepea Senior Member
    533
    581
    Not sure if this is a Prius thing or just a Prime thing (as the Prime is my first Prius), but I've noticed each time I start the Prime for the day, once I hit 12-13mph, a slight "clicking" sound occurs (almost like a soft version of doors locking) as soon as I hit that speed. The usual routine is backing up out of the garage, then putting it in D... and when I hit 12/13mph, I will hear the sound. Funny, I hadn't noticed it until recently (maybe because of noise or distractions, needing to get going) but I've noticed it lately, and sure enough, it's there at the start of using the Prime each day, as soon as I hit 12/13mph. A couple times I even tried going really slow down my residential street for a while to see if it was an "elapsed time" thing or a "speed" thing that triggers it, but it's definitely speed -- for it's only when I first hit 12/13mph when it happens.
    I have no idea what the sound is. It's different than the "shhhhhhhh" brake sound one hears when opening the driver's door before you're ready to start.... it's instead a soft, short clicking sound, like a muted version of doors locking. What is it?
    #1 stevepea, Mar 22, 2018
  2. Mark57
    2,945
    2,736
    OK
    It's the air flow shutters changing position on the front end. Mine does it every time.
    alexcue and stevepea like this.
  3. stevepea
    533
    581
    Thanks. So what are the air flow shutters then, and why would they need to change position at 12/13mph?
    EDIT:
    Just found this:
    From Toyota Canada:
    "When the vehicle is off, the grill shutters automatically open."
    and
    "When the power switch is on, and the engine coolant temp is below 40C, the grill shutters are closed."
    So it sounds like they open when you turn off the car, and once you turn on the car (in decent weather) and hit 13mph it's the sound of the shutters closing (until they're needed to open again).
    Interesting that this came from Toyota Canada (and I didn't see any such videos from Toyota USA)
    #3 stevepea, Mar 22, 2018
    alexcue likes this.
  4. Mark57
    2,945
    2,736
    OK
    Exactly. There is other discussion here about this and there is a reference to a Weber Auto video that talks about them where they take them out and show you how they work.
  5. ppongi
    ppongi Junior Member
    42
    Allen, Texas
    It is the abs break system check ‘ping’ sound at speed of 12-13 mph.
  6. benagi
    benagi Active Member
    525
    280
    Utah
    So which is it, the grill shutters or the abs braking system?
    stevepea likes this.
  7. stevepea
    533
    581
    Sorry to bring this thread back, but... to echo what benagi said, there seems to be two answers as to what the 12-13mph noise is. So... which one is it? :)
