clicking noise from under the driver's dash during hard cornering and braking. traction light on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tekstyle, May 22, 2015.
  1. tekstyle
    tekstyle Junior Member
    48
    seattle wa
    I just noticed that when I am taking a hard right turn such as getting on the freeway or exiting, I hear random clicking noises in rapid successions in random intervals. the traction control alarm also lights up when this happens. is this normal? it sounds like relays are going crazy. I have not tried left turn yet since there isn't many opportunities around.
    editted:
    clicking happens under hard cornering which in turn causes TC light to come on and when still under acceleration.
    #1 tekstyle, May 22, 2015
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It's probably the ABS system pulsing the brakes that you are hearing. Taking turns at speed causes the wheels to turn at different speeds, which the traction control/ABS may interpret as wheelslip or loss of traction.
  3. tekstyle
    48
    seattle wa
    in all other cars I have driven, there is no relay inside the cabin that pulses the brakes when ABS is on. it only turns on when traction control light comes on. I have a feeling it might be a way the car cuts throttle input so the engine doesn't receive fuel. i forgot to mention, this only happens when the TC light comes on and i am still accelerating.
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    Except that in a Prius, unlike in conventional cars, the throttle on the engine doesn't have anything to do with how fast you are moving.
  5. bisco
    49,371
    it's not clicking, it's the car, tsking your driving style. tsk tsk!:p
  6. tekstyle
    48
    seattle wa
    what do you mean by the throttle on the engine has nothing to do with my speed? i understand that traction control on some cars cut throttle while others such as VSA will apply brakes to the inner wheel. The issue only occurs when the TC light is on and under acceleration.
    I just want to know if the clicking is normal. because if it isnt, ill need to take it in to the dealer to have it checked.
    To bisco: i am not asking to have my driving judged. Thank you. just trying to trouble shoot the clicking noise. And if i had another prius to test on, i would to see if the same issue is reproduceable. i am here asking because i dont.
  7. bisco
    49,371
    i was kidding, hence the smiley face. sorry to have spoiled your day.
    Godzuki likes this.
  8. CharlesH
    2,785
    1,152
    Roseville, CA
    In a Prius, the gasoline engine is coupled to the wheels via the Power Split Device. There is no transmission in a Prius. Power from the gasoline engine can be directed either to a motor-generator or to the wheels. The wheels can be powered either by the gasoline engine or a motor-generator (or both at the same time). Thus, there is very little correlation between how fast the gasoline engine is turning (if it is even turning), and power being applied to the wheels. Pressing the throttle pedal is only a computer input to the hybrid control system requesting a certain amount of power, but where that power comes from is up to the hybrid control system, and the answer may or may not involve the gasoline engine. The system really tries to keep the gasoline engine turning at its optimum RPM, if it is turning at all, unrelated to how fast the car is moving.
    The Prius (PiP or standard) is really a distinctive beast.
  9. lensovet
    2,614
    496
    Burlington, NJ
    Yes, this is normal.
    It feels to me like it's the brakes, though I can't be sure. It's annoying as hell but with practice you should be able to find the threshold for the speed and corner radius at which it happens.
  10. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Yes, it's normal. This car has a bit too sensitive TC for my taste.
    And it goes off more frequently when you overinflate your tires.
  11. tekstyle
    48
    seattle wa
    Cool, thanks for clearing up that it is normal. I do feel the TC is overly sensitive. Is there anyways to turn it off completely?
  12. lensovet
    2,614
    496
    Burlington, NJ
    No
  13. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    Yes, see thread below;
    Disabling traction control? | PriusChat
    Enjoy.
