Clicking noise under the dash
Discussion in 'Gen 2 Prius Main Forum' started by Scott56, Jul 18, 2017.
  1. Scott56
    Scott56 Junior Member
    40
    27
    Alabama
    In the last couple weeks I have had this persistent clicking sounds under the dash. The car will be in park and even with the air not blowing it still does it. When I turn the air on it makes a creaky kind of fart sound and it does it again when I switch from cabin air to fresh. Is this an expensive fix? I have read that it might be some sort of air damper issue as far as the creaky door but not sure about the clicking. Does this mean the a/c is about to go out?
  2. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    Does it sound like this? If so, I’m having the same problem.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    W
    Is your AC system ON, when this noise is produced, or not?
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Have you checked the AC system blower fan? If its stuck with dirt, its gonna make that noise. Also, if the blower motor is about to fail, that noise comes up too.
  5. RedUgPri
    RedUgPri Junior Member
    17
    NY
    I noticed this same exact clicking sound when I switched to recirculate the other day but with the heat. I figured the cabin air filter just need to be replaced but I haven't looked into it yet. My theory is that the filters plugged so bad that the blower can stuck enough air. If its not that my second guess is the flapper that control the vent position is stuck. I really hope its not the latter. As for the fart noise mine has always done that when using the AC I just considered it to be normal.
