Clicking noise when braking and creak on susp flex *pls help*
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by munchkinpot, Oct 24, 2016.
  1. munchkinpot
    munchkinpot Junior Member
    Camarillo, California
    hello, experiencing a 15-0 mph constant clicking (click tick click tick ) sound when pressing the brake with steering wheel on slight right, hearing from left driver side. Only happens when braking but silent on turns or anything that has no brake activity. I am familiar with a CV joint clicking turning sound when its bad. On the prius only occurs when brake is applied with a slight turn.
    Also, Im hearing a creak sound upon going inside my garage (slight incline) around the right bottom.
    new owner here, pls help on what it can be.
    thank you in advance!!
  2. orenji
    orenji Senior Member
    5,884
    3,486
    It may be a loose brake pad....
    munchkinpot likes this.
  3. munchkinpot
    thank you sir, but do you think this is not the famous cv/transaxle issue?
  4. munchkinpot
