Clicking relay after starting with a low battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Louis Horvath, Dec 13, 2022.
  1. Louis Horvath
    Louis Horvath Junior Member
    42
    Prevost, Quebec, Canada
    Here's something I didn't expect.
    Prius 2005
    We had hale last week so the tailgate door froze real bad. Tried to open it and broke the band right over the licence plate (the one with the button to open the rear tailgate door).
    One thing leading to another, the tailgate door finally unfroze and it unlocked, leading the lights inside the car to turn on.
    So over two days the battery drained. Bummer.
    I had a trickle charger so I proceeded to charge the battery (plugging it on the fuse box under the hood). After 5 hours I figured I'd have just enough charge to try to start the car. BAD IDEA!
    The car immediately went into an infinite loop, turning on and off every 2-3 seconds, the relay clicking every time.
    Took the key fob out and now each time I try to trickle charge the battery, some relay starts clicking again, every 2-3 seconds.
    Sounds bad.
    I think I'll have to empty the trunk and charge the battery from there ...
    Any suggestions?
  2. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Yeah move the stuff over in the trunk and put the charger right on the battery I'm not sure why you're getting a relay click from trying to charge under the hood but okay unless the car is sitting in the on mode ACC position something try doing all that with the fob 20 feet from the car like inside the house unlock the door whatever and then leave the remote in the house and walk out to the car set up your charger like you have been do you still hear the clicking No let the charger rip sometimes the tab connections up there are to be desired so I usually charge at the battery terminal post in the trunk like I've always done in all my cars where the battery was up front
    Louis Horvath likes this.
  3. ChapmanF
    17,348
    The car's power source ECU has a funny unexpected behavior, sort of like some desktop computers where you can check a box in 'setup' to have it come back to its previous power state after a power failure. If it was off, it's still off when the power returns, and if it was on when the power went out, it tries to turn on again when it comes back.
    I can see times you'd want a desktop computer to do that. It still surprises me they picked that behavior for a car, but they did. If it was on when the 12 volt power failed, you can take the battery out, charge it, leave it sitting for days, whatever, and when you connect the battery back up, the car says "oh! I was on before!" and it turns on again.
    So what happens when you have a terrible, horrible, no good, very bad charge on the battery (five hours on a trickle charger is nowhere near enough) is the car says "oh look! the power is back! I was on before! I should turn on again!" and there isn't enough juice in the battery to successfully turn it on, so the power fails again. Then there is less power being drawn from the battery, so it looks like there is power again, so the car says "oh look! the power is back! ..."
    You can just unplug the fat cable that plugs in at the battery + post, so the car will stop doing that. Then hook up a charger (not just a trickle charger, but one that'll produce 4 or 5 amps), either right there in the back, or take the battery to a workbench and do it there. Give it 15 or more hours on a 4 to 5 amp charger.
    Then, when you plug the car's fat cable back in, the car will again say "oh look! I was on before, so I should be on again!" and now there will be enough charge in the battery for that to work, and you'll be out of the silly clicking loop.
    drone13 and Louis Horvath like this.
  4. Louis Horvath
    42
    Thanks again, your input is invaluable!
    This being said, tomorrow a friend will boost my car. Here's hoping it will be enough to snap the car out of it's funky state ...
    I'll post the results here, if anyone ever has the same issue ...
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    Be absolutely sure of your polarity (+ & -) when you connect anything to the 12V system. Have seen too many posts about "oops, got the cables backwards and now the car is dead". Good luck.
  6. ChapmanF
    17,348
    Even when that happens, it's only mostly dead. Usually needs a fuse link and a few other miscellaneous fuses.
    All dead, you just have to go through its pockets for spare change.
  7. mr_guy_mann
    3,966
    1,914
    NJ-USA
    I'm thinking of the one or two threads where the DC-DC converter failed after a botched jump start or battery hook up.
    Even so, I prefer a little caution before hand vs dealing with any problems afterwards (hey, I'm lazy that way).
  8. Tombukt2
    12,214
    2,155
    Durham NC
    Yeah I don't do too much jumping unless it's with my noco. Other than that I plug up my 8 amp Schumacher battery charger and it works great fan kicks in when it's on full blast and all that stuff plastic has a hanging piece on it 38 bucks or something I do not like doing the jump thing that's why I bought the noco so I don't have to mess with cables and other cars and all that
  9. Louis Horvath
    42
    Boosted the car and IT WORKS! All the clicking is gone!
    Thanks all, it's been (as usual on PriusChat) a learning experience.
    NOW ... the culprit behind all of this is ... a hatch door that won't open.
    Tried pulling that "magic handle" in the trunk to no avail.
    I can see the metal hook and it's still up.
    So it's either something jamming the lock OR the electric lock is broken.
    Anyone with experience?
    If required I'll post some pictures later tonight.
    So that my battery doesn't run down again I closed out all the lights that turn on when the hatch door is open ...
  10. Louis Horvath
    42
    Note : I'm reading up as much as I can. I will tell you later on if the actuator actually makes a noise.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    You need to connect that "trickle charger" for about 24 hours in an attempt to fully charge the battery.
    BUT even with that, your grief with the battery may not be over.
    How old is it ??
    Often an old battery that has been run flat will "self discharge" fairly fast after that and only a new one will fix it.
    Note: I hope your little charger really is a fully automatic tender type charger.
    That is NOT the same as a trickle charger, which is not recommended for much of anything.
  12. Louis Horvath
    42
    I got a friend to boost my car and it worked!
    I'm counting my stars, the battery is back and it's strong. Last night was really cold and today the car started like nobody's business. It's a good thing. Ever since that "war you know where" some corporations have jacked their prices like vultures. Up here in Canada the battery required for a Prius went from 250 canadian rupees to 550 nordic pesos !!! COME ON! Lay on an extra 50$, don't double the price!!!
  13. mr_guy_mann
    3,966
    1,914
    NJ-USA
    You really need to properly charge your battery (& get it tested). Your 12V can "start" your Prius if it's at 12.0 or (or even 11.5V- maybe). But that's way discharged. It can work as it is ("like nobody's business") until it doesn't.
    Personally, I try to keep my car as reliable as I can.
  14. sam spade 2
    7,035
    2,799
    2017 Prius c
    You said that already. That proves almost NOTHING.
    The 12 V battery does not start the car, it just boots up all the computers.
    The engine actually starts from the HV hybrid battery.
    Second time asking how old the battery IS.
    I am not the only one offering this advice.
    Ignore it at your own risk.
  15. Louis Horvath
    42
    @sam spade 2
    Thank you so much for your time.
    Took an extra day but the 12V battery died completely.
    Couldn't find any date on the battery but it was mostly written in Japanese and looks moderately old.
    Also the new battery - although with the same specs - is a little larger than the original and the original harness doesn't fit. It will not move horizontally but if I decide to drive upside-down this will be an issue (how very unlikely!)
    As for the lock on rear hatch, dousing it with liberal amounts of gigaloo fixed it. Although now I'll have to find a way of making the cheap hatch handle stay in place when I pull on it - the plastic is broken.
    As a bonus, changing the 12v battery also fixed the "Check engine" light on the dash I was having for the last 2 years. Either something wasn't properly plugged into the back ECU or the new battery has that extra oompf that oils that squeaky wheel.
