Climate Change Data Error
Discussion in 'Fred's House of Pancakes' started by fshagan, Aug 11, 2007.
  1. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    Many of you have seen the pictures of the ground temperature stations used for data collection, and the violations that have gone unreported to either NASA or other governmental agencies (incinerators next to them, A/C units, paved areas added adjacent to them, obviously moved sensors, etc.) Now, Steve McIntyre of Toronto has "reverse engineered" the GISS data (NASA's Goddard Institute for Space Studies) and found an error (NASA will not release the program source code used to crunch the numbers, perhaps for legal reasons).
    His site, http://www.ClimateAudit.org is down, some say due to a DOS attack, and others say just due to the increase in traffic due to the discovery of the error. Here's some info on what he found from http://www.norcalblogs.com/watts/:
    Science is self-correcting, and the process of refining the numbers like this is a sign of a healthy scientific process. More attention to the integrity of the data should help us make intelligent decisions regarding whether or not global warming is occurring, and if it is, if it is caused by man, and if man causes it, what can be done to reverse it.
  2. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    Fascinating. I bet this won't get ANY play in the popular press, since it's not the "sky is falling" type of global warming story they like to beat us over the heads with.
    I had trouble linking through on your links, so perhaps you are right - Steve is being attacked by a DOS. Perhaps it should be called a DOT (Denial Of Truth) attack.
    NASA not releasing the data is beginning to smell like Mann's now discredited "hockey stick" saga. Steve destroyed Mann's hockey stick all the while Mann refused to release the source data. What kind of science is this? I thought reproducibility was a cornerstone of the scientific method. Perhaps it is unless you have an agenda to push.
    For anyone interested in some of the other problems with surface temperature measurement sites, see this.
    Hopefully the turds presumably attacking Steve's site won't attack Pielke's.
  3. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    Here BTW, is one of the images that apparently started the ball rolling with respect to questions about the CONUS temperature stations.
    Apparently there was a 4 degree C jump in temperature at this station in 1999 - right when the AC units were installed.
  4. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Now someone explain to me who's faking the glaciers and polar ice caps melting?
  5. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    <div class='quotetop'>QUOTE(Stev0 @ Aug 11 2007, 07:06 AM) [snapback]493966[/snapback]</div>
    It's all Clinton's fault!!!
  6. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Smoke is pouring out of No. 3 engine, its power is starting to falter, the cabin is getting uncomfortably hot and the flight crew is starting to sweat, but the captain shrugs and points to the oil temperature gauge, the only gauge to No. 3 that isn't pegged or dying, which indicates a mild rise but is still solidly in the green, and says "Nothing to worry about; I know the entire instrument panel seems to indicate the engine's afire, but look, the oil temp reads good, so there can't be anything really bad happening to that engine. Relax."
    MB
  7. Devil's Advocate
    922
    Las Vegas, Nevada
    When the galcial model considers something other than temperature i let you know why the glaciers are retreating. All glaciers melt, all the time, its just that when they expand (or don't shrink) they are actually just getting more snow. Maybe the rain/snow pattern over these glaciers have changed causing less snow to fall on them and for that snow to fall elsewhere? Since GW models don't consider percipitation, i wonder.
    I am glad that the GW crowd wasn't around during the las ice age since if they were I would have grown up under a few hundred feet of ice in northern Ohio!!
    I wonder what SUV's caused that ice to melt?
  8. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Devil's Advocate @ Aug 11 2007, 12:57 PM) [snapback]494014[/snapback]</div>
    *cough*
    *cough*
    "Oh, look! Our canary died in this mine! That's OK, canaries die all the time!"
  9. tballx
    tballx New Member
    130
    Edmonds
    <div class='quotetop'>QUOTE(Devil's Advocate @ Aug 11 2007, 10:57 AM) [snapback]494014[/snapback]</div>
    The GW crowd? What a moronic ad hominem attack. Please wow us with your ability to marginalize those that don't agree with you by lumping them into a "group." All glaciers melt all of the time? Therefore by definition those that do not agree with you espouse that no glacier should melt any time? Every hear of the false dilemma error? GW models don't consider percipitation (sic)? Where do you get this stuff? Cite a published peer reviewed scholarly source or kindly go away.
  10. fshagan
    1,766
    Science is science, and the ad hominem attacks and useless metaphors are hardly worthwhile.
    First, I could be wrong but I don't think the data is kept secret. The program they use to crunch the raw data is proprietary. So I suspect that NASA isn't releasing the source code for the program because its protected by copyright, and they can't release it. Steve's breakthrough came because he "reverse engineered" the results by looking at the source data, and discovered the Y2K error. I haven't heard this error explained, but I wonder if it was a simple "year zero" type of error in the math routines in the program?
    The other thing to keep in mind is that this affects only the ground station temperature measurements of the US, and not the world-wide numbers. There are some problems with that data, and my understanding is that they already add a fudge factor to the calculations to try and account for urban "hot spots" due to the increase in thermal mass like pavement and buildings. But they haven't been adjusting for incorrect installation of the temperature sensing equipment, including it being in shade part of the year, incinerators installed next to them, etc.
    If the solar-heat advocates are right, then we will see a cooling trend over the next ten years rather than a warming trend. If the climate change folks are right, we'll see a warming trend. Correcting the US data is an important step, and may shorten the amount of time we have to wait to see if we are in a warming or cooling trend.
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I predict most will agree that there is a problem only after Hawaii disappears and coastal states include Nevada and Pennsylvania. Does it really matter if it is entirely natural or aggravated by civilization? The end result is going to be the same.
  12. scargi01
    scargi01 Active Member
    784
    57
    Missouri
    <div class='quotetop'>QUOTE(JimN @ Aug 11 2007, 05:07 PM) [snapback]494077[/snapback]</div>
    It matters because if the cause of the warming is not man then we should spend the money on dealing with the effects of warming rather than on trying to reduce our impact.
  13. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Well, as long as you are trying to play the objective thinking person, head over to realclimate.org and read some real science discussion.
  14. Mirza
    Mirza New Member
    898
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(05_SilverPri @ Aug 11 2007, 03:46 PM) [snapback]494093[/snapback]</div>
    Actually nearly all of the efforts used to reduce impact have huge returns of investment regarding health, economy, and overall sustainability. Try again :)
  16. Alric
    Alric New Member
    1,526
    87
    <div class='quotetop'>QUOTE(F8L @ Aug 11 2007, 08:31 PM) [snapback]494143[/snapback]</div>
    And even if its in part due to a natural process, the amount of greenhouse gases we pump to the atmosphere would have to greatly exacerbate the process.
  17. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(Alric @ Aug 11 2007, 06:50 PM) [snapback]494152[/snapback]</div>
    Especially when coupled with a degradation of the processes that help to cycle GHGs. Like reaching a bifurcation point, we will see a complete restructuring before too long or the network will collapse. ;)
  18. Wildkow
    Wildkow New Member
    5,270
    37
    36
    What is the amount of greenhouse gases we (Humans) pump into the atmosphere as compared to other natural processes?
    Wildkow
    <div class='quotetop'>QUOTE(fshagan @ Aug 11 2007, 12:11 PM) [snapback]494026[/snapback]</div>
    1) Non-disclosure agreement.
    2) If this fellow reversed-engineered someone’s computer program he broke the law but if it’s just data he’s probably ok.
    3) I could be wrong.
    Wildkow
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(Wildkow @ Aug 11 2007, 07:19 PM) [snapback]494164[/snapback]</div>
    "Burning fossil fuels, making cement, burning forests and grasslands, and other human activities release nearly 30 billion tons of CO2 every year, on average, containing some 8 billion tons of carbon. (Burning Fossil Fuels 49%, Industrrial Processes 24%, Deforestation 14%, Agriculture 13% source ~ World Resources Institute). About 3 billion tons of this excess carbon is taken up by terrestrial ecosystems, and around 2 billion tons are absorbed by the oceans, leaving an annual atmospheric increase of some 3 billion tons per year. If current trens continue, CO2 concentrations could reach about 500ppm (appraoching twice the preindustrial level of 280ppm) by the end of the twenty-first century."
    Estimated Fluxes of Pollutants and Trace Gases to the Atmosphere In million metric tons/yr.
    Species.........................Natural..........Anthropogenic
    CO2........................................370,000........29,600
    CH4.........................................155..............350
    CO...........................................1,580...........930
    NMHC (nonmethane hydrocarbon)..860...........92
    NOx..........................................90................140
    SO2..........................................35.................79
    SPM (suspended particles)...........583...............362
    Cited from "Environmental Science - A Global Concern. 8th Edition (William Cunningham, Mary Ann Cunningham, Barbara Saigo)
    I urge you to read the Millenium Ecosystem Assement Report to see how our global ecosystems are fairing and then refer back to this information and try to realize how we are exacerbating the problem by destroying the very systems that we need to help us relieve this problem.
  20. scargi01
    784
    57
    Missouri
    If the returns are so great then how come it isn't happening on its own already?
