climate control--can you help an oldster understand?
Discussion in 'Gen 2 Prius Main Forum' started by goldprius, Aug 2, 2007.
  1. goldprius
    goldprius New Member
    Well, I am not quite a newibe, having had my 2007 Prius for about 6 months. I am used to an old fashioned climate control where you just slide it around & it gets done.
    SO! I am a person who mostly likes fresh air & hardly ever runs a/c regardles of car. I do also care about mpg, of course! To get just fresh air out of the dashboard into my face.. well, there is a button towards the buttton left for a/c. I can turn that "off." However, in the very top leftish of the display, no matter what I do, it seems to say a/c. Does that mean it really is on, regardless of what other options I choose? If I want to just get a cool breeze of outside air, should I set the temp to LO or does that make the a/c cut on?
    On simpler cars, you would put the temp on blue (cold) and that made the fresh air blow in if you didn't hit the a/c button.
    As to mpg, I know I read to close windows & set a/c 2 degrees below ambient temp. Does that basically mean turning off a/c and running with windows open is a bad thing?
    THANKS!
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(goldprius @ Aug 2 2007, 06:48 PM) [snapback]489709[/snapback]</div>
    Welcome to Priuschat.
    As a partial answer to your question I am attaching a write-up by Tony Schaeffer who puts it much better than I could.
    "Toyota's use of the term Air Conditioning in the Prius is technically correct, but many drivers confuse Toyota's use of the term with the common belief that Air Conditioning refers only to the cooling of cabin air.
    The light on the dash indicates Auto A/C. If that light is on, the system will make all the decisions about air volume, air output, air source, compressor status and heat status based upon the temperature setpoint that is changed either at the steering wheel or on the MFD. The Prius system is fully automatic and behaves the same as nearly every other automatic climate control system I have ever used.
    Now, with the light on, if you go into the MFD and start adjusting the system, the Auto A/C light will go off. That means that the system is not fully automatic anymore. Starting at Auto A/C, as soon as you manually adjust the fan speed, the system will not be able to adjust the fan speed automatically. That is why the Auto A/C light goes off. Not because the system is not going to run the A/C compressor, but because it is not fully automatic anymore. The same goes for air output, if you manually adjust that from the Auto A/C light, the system will not be able to choose the air output.
    The temp setting does as it indicates. Its goal is to keep your cabin at the temp you indicate. It will heat as necessary and use the compressor as necessary to achieve these goals.
    There is an A/C button on the MFD in the upper left corner. I call that the A/C defeat switch. If the yellow bar at the top of that soft button is on, it means that the automatic system has access to the A/C compressor. If you press the A/C button and the light goes out it means you have told the system that it may not use the A/C compressor. This light does not indicate when the vehicle is using the A/C compressor. You have no direct control over when or how the system uses the A/C compressor. You can adjust the cabin temp up or down, but that is the only control you have aside from the A/C defeat switch. I cannot stress this enough, use your A/C or loose it. The health of an A/C system is based upon it being used. Compressed refrigerant, as it goes through the system, carries with it refrigeration oil, which is mostly used to lubricate the compressor, but also keeps the o-rings and seals fresh and soft. If you intentionally choose to not use the A/C you are choosing to let the system dry out and that will require future expense to bring it alive again. The Prius battery also requires a "room temperature" environment for most efficient operation. If the interior of your cabin is hot after sitting out in the sun, the Prius uses the climate control system to bring the cabin temp down to a level which helps the battery operate efficiently. The battery does not run efficiently above 100 degrees and doesn't do that well when it is freezing out, so a pleasant cabin temp is also pleasant for the battery.
    So, what I'm saying is that you should never defeat the A/C system as it does more than just keep you comfortable.
    Additionally, the compressor is not on or off, as in most cars, but is variable speed and runs at speeds necessary to provide the appropriate amount of cooling to the system. In the summer, as the cabin cools down the compressor will slow down. This is a significantly more efficient A/C design than in conventional vehicles in which the A/C compressor is engaged or not engaged and nothing in between. You should also be aware that the A/C compressor is electric and as such does not load down the engine with a high demand pulley accessory. Instead all of the energy used to run the compressor comes from the HV battery and electrical system.
    I have discovered that I loose only a couple of MPG in the summer with the A/C, if that much. As such I do not consider it a sufficient loss in MPG to choose to go without A/C. And considering the additional benefits of running the A/C (circulation of oils, battery cooling), there is no question that the auto A/C system that Toyota put on the Prius is there for a reason and is as integrated into the vehicle's operations as the HSD system."
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It is a bit of a dance for the Prius to get a "vent" setting.
    But it seems you've pretty much figured it out.
    The (AC) button on the touch screen should not be highlighted (ie it should be off). Temp should be on "Max cold" otherwise it'll let a little ICE heat from the venting around the ICE.
    Finally, make sure the "auto" feature is off....to do that you have to just touch one of the fan speed 'buttons'. Of course you want recirculate off, but I think that goes without saying.
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    At this time of year, where I live, it is comfortable to shut the AC off on the morning drive to work, but AC is mandatory at lunch time and later in the day.
    So in the mornings, I hit the Climate button next to the MFD, choose a fan speed that I like, hit the button that sends the air to the dash vents (if necessary) and then turn off the AC with the button in the lower left corner.
    At lunch (if I drive the car) or later in the afternoon, I just hit the Auto AC button on the steering wheel to turn the AC on again.
  5. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    Used to play with climate control screen all the time, but I finally decided that Fiona is smarter than I am so I just press the AC button on the steering wheel & let her do what she will. I do adjust the desired interior temperature from time to time, and I religiously turn the AC button off when I am gliding into my garage at the end of the day (and each time I park on intermediate trips).
  6. jamarimutt
    jamarimutt New Member
    985
    <div class='quotetop'>QUOTE(Grandma Judy @ Aug 3 2007, 10:50 AM) [snapback]489914[/snapback]</div>
    This is just what I do. Just set it (at 75 degrees) and forget it.
    If you use the air conditioner most of the time, you really don't need to turn it off. The Prius' compressor is electric and thus places no load on the ICE.
  7. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(goldprius @ Aug 2 2007, 07:48 PM) [snapback]489709[/snapback]</div>
    I tried to do that when I first got my Prius, then gave up. When I opened it up to fresh air with no AC and temp to lowest, it blew warm even if it wasn't that warm outside. It's such a hastle to do that too... too many buttons to push, also you must move temp all the way to low. Now I just leave it on auto or off, open the windows if I don't want AC. Ahh, for the days of mechanical levers to push!! Some things shouldn't be computerized for the sake of computerizing it... like books for instance! When was the last time you had the battery run down on your paperback or dropped it and broke it?
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Having the windows open at speeds greater than, say, 40 MPH, will give you poorer MPG than using the A/C with the windows up. Press the "recirc/outside air" button to select "outside air" if you use A/C and want to ensure you get "fresh" air (you are assuming the air outside is fit to breath - this is less and less probable as we "advance").
    I installed the air deflectors that go at the tops of the side windows, because here we don't need A/C for more than a few weeks of the year. Many of you southerners would say never - a "hot day" for us is 30C (86F), though last year we did hit 40C - once. Anyway, this allows me to leave the side windows down about 1-2" without the worry of getting rain or dew inside. Still noisier than windows up, and I wouldn't do it on the highway. I use A/C auto when it's warm and fan on "4" when it's not.
  9. jiepsie
    jiepsie New Member
    267
    Remember that the A/C is not just there for our comfort, it's there to keep the HV battery happy to, the battery works best when it's not too hot or too cold. I'm pretty sure that's why the car has computer controlled climate control as a standard feature.
  10. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    <div class='quotetop'>QUOTE(lowlander @ Aug 3 2007, 12:27 PM) [snapback]489975[/snapback]</div>
    Well I thought I understood how to work the climate control in my car but now I'm confused.
    Are you saying that I can't be warm in the winter because the battery will be uncomfortable? Because I have real problems with the cold and I want the heater on full blast in the winter.
    When outdoor temps are in the 70s and I'm on local roads driving 30 mph, I don't want cold air from the A/C blasting on me, I want the windows open so I can feel the breeze. So I leave the A/C off, make sure the temp is set below the air temp, and leave the fan on low.
    Sometimes during long afternoon drives the car can get warm inside even when it is in the 50s and 60s outside. But in these cases I don't want cold air blasting from the A/C because that's too much. With my old car I just turned the air temp dial all the way over on the blue side (coldest setting), turned up the vent fan and the car would be comfortable using outside air only. I plan to do that with the Prius when the weather gets cooler again.
    At first with the Prius I had the Auto A/C on, but I found the A/C would come on and blast cold air on me when I didn't want it, so I turned it off. Now if I want A/C I turn it on, and if I don't feel it's necessary I turn it off. If I am comfortable (not hot and not cold), I fail to see why the battery should have a problem. If it needs extra cooling there should be a mechanism for that that is separate from the climate control for the people in the car.
  11. kettledrum
    kettledrum Member
    181
    Indianapolis, IN
    So I should not be driving with the climate system off and the windows up and the cabin temperature between 100 and 110 degrees F ? :huh:
  12. efusco
    19,891
    1,192
    Nixa, MO
    Oh goodness....the rumors that start here.
    The primary job of the AC is driver/passenger comfort. A side benefit is passive heating and/or cooling of the battery pack.
    The battery likes to be warm...80-90degree range is probably ideal. So, in the summer if the cabin is over 100 degrees having the AC on and cooling the battery down to 90 or so is a benefit. In the winter when the temps are 20 degrees having the heat on to warm the battery to 60 degrees is benefitial.
    Nobody needs to suffer the heat or cold unnecessarily. Some of us do it intentially, however, just for good fuel economy. My therapist says that's ok and so do all my invisible friends!
  13. Vebev
    Vebev Junior Member
    28
    Boise, Idaho
    I just set my climate control to "auto" and set the temperature to 75.
    I don't like cold air blasting at me either so I turn the vents to blow elsewhere.
  14. bmwquickspeed
    bmwquickspeed New Member
    38
    Scottsdale
    Thats the whole reason I don't use the Auto Feature. I like the air blowing at me I just don't like it blasting at me.
    If I leave the setting on Auto A/C at 75 degrees and it is over 100 degrees outside the AC blows at me at the highest possible speed.
    I usually put the fan on level 2 or 3 and set the temp between 75 and 78 degrees and it get the job done great.
  15. Prudence
    Prudence New Member
    109
    Hudson Valley
    <div class='quotetop'>QUOTE(bmwquickspeed @ Aug 3 2007, 03:39 PM) [snapback]490090[/snapback]</div>
    I'm amazed by how cold the AC gets. I end up putting it on 78 after it gets cold in the cabin, otherwise I get too cold at 75. It works very well. I used the "vent" setting in the spring, it's not that hard to do. My last car had auto air also and never got as cold as this one and putting it on a "vent" mode wasn't readily apparent either. Once you get used to it, it really is a matter of touching just a few buttons.
  16. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    <div class='quotetop'>QUOTE(goldprius @ Aug 2 2007, 08:48 PM) [snapback]489709[/snapback]</div>
    Just set it on auto, adjust the temp. to your liking, then sit back and enjoy the ride.
  17. YoDaddyAlex
    YoDaddyAlex Member
    271
    not sure if this is how it works... but for me, I would think that selecting a temperature, even say 85, would cause the heater to kick on... but in my car, it does not, I have to set the temp to something high, then turn the AC button off, and then the heater kicks in instead. Kind of strange, is that how it is designed or is my system all weird?
  18. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(YodaddyAlex @ Aug 8 2007, 08:09 AM) [snapback]492393[/snapback]</div>
    That is not how it is supposed to work. Either your system is malfunctioning or you do not wait for the engine to warm up before you start messing around with the controls. In the heat mode, the fan does not start blowing until after there is warm coolant. When you manually raise the thermostat, electric coils are activated to supplement the engine produced generated heat.
  19. goldprius
    Wow, original poster here, thought this thread had died off after a couple days after posting, but see more answers (& questions!) here.
    I honestly usually don't use a/c, as I am a person who tends to be cold. But today was the first time I saw
    102 for the outside temp. per the Prius dashboard. Hearing the battery doesn't like off 100, I put on the a/c.
    I had read somewhere to set it at 2 degrees below ambient temp. I kept pushing it up, hit 85, then "higher,"
    where I left it at. It felt like hot air coming out. So I put it on 85. It was a lot cooler than "hot" in my opinion. So I left it there. When I first turned it on on "auto," the fan was blowing so hard I couldn't hear. I was going to turn down the fan speed. But, by the time I got to the next red light, it had already done it itself. So, I guess it really is pretty smart!
    SO, here is another question for y'all on climate control. About a week ago, it was maybe 70s in the morning when I left for work. The outside of the windshield kept getting wet/fogged (not the inside). No matter how I set the climate control (& I know I didnt' try all the options), I kept having to blip the wipers every 2 seconds. I think I tried a/c to windshield & heat to windshield.
    I think this was a very unusual weather condition. However, with fall/winter coming, I will ask. For cold weather/froster windshield. In my most of my old vehicles, you turned the bottom thingie up to red & blasted the fan. In some vehicles, the a/c automatically came on to defog the inside.
    What can I expect from the Prius?
    Thanks.
  20. dogfriend
    7,512
    1,185
    Carmichael, CA
    For defrost, press the button on the lower right side of the steering wheel. There are 3 of them, one is for recirculate/fresh air, one is for windshield defog/defrost, one is for rear defrost / heated mirrors. The one for the windshield defog/defrost has a symbol that is wedge shape with the wider part at the top.
    For more info, see Section 2-9 in the owners manual.
    [attachmentid=10474]
