Climate prep
Discussion in 'Prime Fuel Economy & EV Range' started by 4rpr15, Nov 30, 2017.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Who uses this during charging and should I do it often, only at times or when? I’m sort of confused on this feature. I know what it’s for where it can keep the car warm or cool but how often should it be used and why?
  2. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    It should used whenever you think the car will use a lot of energy either heating or cooling the car so that it can use the grid electricity rather than drain the battery.
    Your car your rules
    iPhone ?
    Arctic_White and Data Daedalus like this.
    49,520
    and don't forget the battery warmer.
    Data Daedalus likes this.
  4. 4rpr15
    1,056
    375
    WI
    How does that go.
  5. 4rpr15
    1,056
    375
    WI
    Meaning if I leave it on while charging I won’t have to turn on my heat or a/c while driving?
  6. bisco
    49,520
    you will, but you start out warm or cool, which helps.
  7. bisco
    49,520
    don't know the details, but prime has battery preconditioning, which helps make it more effective.
  8. 4rpr15
    1,056
    375
    WI
    But your saying I shouldn’t forget about it, lol?
  9. bisco
    49,520
    well, it's been discussed in other threads. i don't have a prime, but i have read about it. it should also be in your o/m.
