Clocked
Discussion in 'Gen 2 Prius Main Forum' started by Benjamin13295, Aug 11, 2018.
  1. Benjamin13295
    Benjamin13295 Junior Member
    62
    Slovakia
    Is there anyway I can find out if my Prius was clocked?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    define "clocked"......
  3. Benjamin13295
    62
    Slovakia
    Rolled back miles or km on the odometer
  4. KK6PD
    4,003
    944
    118
    oh, OK, that is a good question! If it's a mechanical odometer, you would have to pull it and look for arks on the case indicating someone tried to open the case. the electrical type, I don't know. I assumed they would be hard to reprogram.
  5. PriusCamper
    PriusCamper Senior Member
    11,097
    4,516
    Pacific Northwest, USA
    There's a service mentioned on here that replaces odometer units and programs them to match the same mileage as the broken one... I suspect that business would be able to check for that...
  6. bisco
    49,478
    not that i know of...
  7. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
  8. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    The best way to check if the ODO has been rolled back significantly, is to use electronic record service history. Does Carfax do that? Or use the Toyota owner’s website to see the service history. It is very obvious that the combination meter has been played with, when the mileage jumps back.
    [EDIT] Not sure what you will have available in Slovakia (is there a CarFax type service?), but I hope you get the gist of what I’m saying.
