clog inside the intake manifold....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by monash, Mar 5, 2019.
  1. monash
    monash Junior Member
    Danbury, CT
    Very rattling sound start coming from my Prius when cold start happens. Tried to identify with Toyota dealer and they indicated that its issue with some clog inside the intake manifold. Does any one seen this kind of an issue during cold start.
    Regards,
  2. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    I never had the rattle on cold starts until the headgasket failed.
    Raytheeagle likes this.
  3. monash
    Danbury, CT
    so does that covered by Toyota? or something as a owner's maintenance. I have been using Costco Gas for exclusively so not understanding the reason of the clog and this issue.
    Also any suggestion on doing with Toyota or somewhere else?
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Better clean before engine blows
  5. The Critic
    3,193
    2,327
    CA
    If a clogged EGR was the sole reason for head gasket failures, I would have expected to see one of the following conditions with my failed headgasket:
    1) deterioration by cyl #4, which is the closest to the EGR circuit
    2) equal deterioration of the entire headgasket.
    Instead, it was the area between cyl 1 and 2 that failed, and the head bolt nearest the failed location had lost torque.
    #5 The Critic, Mar 5, 2019
  6. The Critic
    3,193
    2,327
    CA
    I can’t speak to your particular vehicle, but if the dealer has diagnosed the manifold to be a problem, you need to correct that issue before moving onto other ones. In certain states, the manifold is covered for 150K.
    On my vehicle, I only experienced the knock (misfire) at startup until I experienced a headgasket failure.
  7. monash
    Danbury, CT
    thanks for the update. what do you mean by that manifold covered ?
  8. monash
    Danbury, CT
    Do you think by using any cleaning agents can remove the clogs they are talking about?
  9. Mendel Leisk
    40,582
    Watch the @NutzAboutBolts videos, pinned at top of 3rd gen maintenance forum. There's intake manifold cleaning, EGR pipe cleaning (a good one to start on), full EGR cleaning, and Oil Catch Can install is good too.
  10. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Cylinder #4 is closer to EGR, yes. From what I remember on the forums, when EGR is partially plugged, cylinder 4 usually gets more EGR and usually cooler than the rest of the cylinders. The Cyl 1 channel is normally the most restricted and has the most carbon buildup.
    With the IDs of the EGR channels the same, even without deposits, a longer channel would have more restriction than a shorter one.
    #10 mjoo, Mar 5, 2019
  11. The Critic
    3,193
    2,327
    CA
    Sure, I can imagine that possibility. But by that logic, the gasket should reflect this.
  12. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    I'm not sure I understand. Which channels were the most restricted?
    Pixel XL ?
  13. The Critic
    3,193
    2,327
    CA
    My EGR cooler was not clogged. I had cleaned it 5K ago, and even then, it was not clogged.
    I have not personally examined a headgasket that was removed from a car with a "clogged" cooler. But every failed Prius 1.8L headgasket picture that I've seen, has shown deterioration between cylinders 1 and 2. So, for that reason, I am skeptical that the EGR is the true cause of the headgasket failures.
    CR94 likes this.
  14. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    You may be right..
    Not all head gasket failures come from EGR restrictions obviously. Even cars without EGR blow headgaskets. I do think a clogged EGR accelerates head gasket wear due to the resulting greater combustion temperatures and pressures. A failing water pump is another contributor.
    Pixel XL ?
    #14 mjoo, Mar 7, 2019
    Mendel Leisk, RMB and The Critic like this.
  15. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I have a couple theories here that I may want to add here.
    Little things do add up. Head gasket failure can be caused by one bad system, like 1) increased combustion temp with the lack of EGR gas, 2) increased combustion ratio with regular octane gas-- from induction of fluid/oil or carbon buildup causing pinging, 3) over heating with failing water pump or coolant leak etc. Now what about but a little bit of each? All of the above are happening in our little 1.8L engine with enough age and mileage on it. So one may not have a fully clogged EGR cooler or totally dead water pump, but over time and mileage, things do happen, just usually doesnt happen to Toyota engines, well, until recently.
    A second theory to explain why is the head gasket always fails between cyl 1 and 2, is because the cooler coolant from the radiator lower hose goes back into the engine from cylinder #4 and flows out of the front of engine at cyl #1. 3 and 4 gets cooler coolant while 2 and 1 gets hotter coolant.
    I am trying to go by some of the readings here in Priuschat and old memories from school so I can be wrong LOL
    Mendel Leisk, mjoo and Raytheeagle like this.
  16. hotelprisoner
    hotelprisoner Member
    101
    85
    Ontario, Canada
    Technology
    I like your theory RMB. The missing data, in my opinion, might be found on a Cylinder Head Temperature gauge similar to what one would find in piston powered aircraft.
    RMB likes this.
  17. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Isn't it possible that bolt "lost torque" (tension, actually) only because the gasket disintegrated out from under it?
    Thanks for your expert write-up of your expert work repairing this scary problem!
    Raytheeagle and The Critic like this.
  18. The Critic
    3,193
    2,327
    CA
    I suppose that is a possibility, too. There are multiple possible reasons for the failure. But the moral of the story is - it is a very real possibility on the 10-15 Prius at high mileage, so buyer beware.
    Raytheeagle and CR94 like this.
  19. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Is it possible to check head bolt torque without removing the head?
    Pixel XL ?
  20. The Critic
    3,193
    2,327
    CA
    The issue is that the head bolts require angle torque. 36 ft-lbs + 90-deg + 45-deg. There is no way of accurately re-torquing the bolts without removing them and starting from scratch. In theory, MLS headgaskets should not require any re-torquing.
    Raytheeagle and mjoo like this.
