Close windows
Discussion in 'Gen 4 Prius Main Forum' started by Hamza Masarwa, Jun 5, 2023.
  1. Hamza Masarwa
    Hamza Masarwa Junior Member
    35
    Jordan
    How can I close all the windows and the sunroof with the car key? 2016 Prius
  2. Tideland Prius
    16,643
    You can insert the key into the driver’s side keyhole and turn to lock the door and hold it there until the windows close. If you’re outside of the US, you might be able to use the LOCK button the key fob as well.
    The issue is that the key fob method is turned off by default from the factory. Either use an OBD-II dongle and phone app to change it or go to the dealer.
