"Cloudy" and/or "fogged" NAV screen
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Apr 7, 2025.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,682
    Iowa
    Any advice?
    My older brother cleaned his '24 Camry NAV screen with some window cleaner and it is now murky.
    Searches are a bit mixed, but most people report rubbing alcohol or Lysol wipes are the cure.
    Any personal experience?
    kris
    51,011
    interesting. i always clear our '24 hycam with windex and haven't had an issue.
    Prodigyplace likes this.
  3. ChapmanF
    17,180
    I do know alcohol can clear up fogged shellac, but that would probably help more if your brother's nav screen was from the 1920s or so.
  4. Stevewoods
    Stevewoods Senior Member
    652
    1,062
    Seattle, WA
    Gorsch, an actual post in FHOP that does not originate with the ruthie mobile.
    I managed to muck up my clear screen over the speedometer.
    Have not tried to fix it. Maybe I should
    Trollbait and bisco like this.
  5. Stevewoods
    652
    1,062
    Seattle, WA
    Tried a 50/50 mix of 99 percent rubbing alcohol and 70 percent rubbing alcohol. Which, I suppose, works out to 80 percent?
    WORKED. I take no responsibility for the results of anyone else trying said formula.
  6. ChapmanF
    17,180
    I get 84.5%, which is the same as one solution calculator on the web says, so at least I did it the same way as somebody.
  7. ETC(SS)
    6,903
    Relief is only a click away, my friend!!
    Cannot help you with the fog, BUT.........
    Ah, Relief! (turn up the squelch) | PriusChat
    Stevewoods likes this.
  8. Stevewoods
    652
    1,062
    Seattle, WA
