Clunking, banging noise when starting.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by txtabby, May 30, 2016.
  1. txtabby
    txtabby 2011 Prius 4
    123
    Austin, TX
    Here's an odd one. Yesterday I started my 2011 Prius, about 3 seconds later (Im guessing here) I pushed the A/C button, the engine started (at the same time), and I got this horrible grinding, clunking, bucking noise from under the hood. It lasted for about 5 seconds then stopped and everything was fine. Engine ran smooth, A/C was running. I turned off the A/C thinking that might be it and started it again, again everything ran smoothly. I pushed the start button the shut down the car, waited about 15 seconds, pushed it again, all normal, again with the A/C on. I put into drive and moved forward, allowed the engine to start, no problems. Smooth operation, everything normal.
    I gather it'd be a good idea to take it in, but want to know how many "on-off cycles" until a problem is erased from memory. I did drive it last night (everything ran just fine) and went through 3 "cycles".
    Any ideas on what this could be? Bad fuel?? I have a 2011, with about 38k miles on it. This is the second Prius I've owned and have never had a problem before, let alone something like this.
    49,488
    i don't like the sound of that. any chance you shut it down while the ice was still warming up the time before?
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
