Clunking noise after new parts installed
Discussion in 'Gen 2 Prius Technical Discussion' started by ANDREW BERMAN, Apr 29, 2022.
  1. ANDREW BERMAN
    ANDREW BERMAN Junior Member
    Killbuck, OH, United States
    08 Prius charged cv axles, inner and outer tie Rods, sway bar links, lower ball joints, new plugs and coils last year, hubs, oil change and transmission fluid change and hybrid battery it’s showing 45.5mpg and I’ve gone 90 miles and used a half tank fuel, check engine is on for an evap leak small.
    What can I be missing that I’m getting such bad gas mileage? It does seem to take more effort going up hills and I hear what sounds like a rattling noise when I hit bumps or holes
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    How many miles on the vehicle, and is the HV battery still an untouched OEM?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Something is off here.
    The car thinks it's getting 45.5 mpg due to its calculations of fuel usage using the injectors.
    You've driven 90 miles, which should be ~2 gallons of fuel, based on computer.
    But, you're saying you've actually used 4 or 5 gallons.
    I see a couple options.
    1. Your fuel gauge is way off
    2. You have a significant fuel leak somewhere (mpg calc doesn't take into account fuel that may be pissing out of a hole)
  4. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    If you refill the tank does it take 4 gallons or something less?
