Clunking noise at front of engine when baring engine by hand
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raqune, Mar 15, 2026 at 2:39 AM.
  1. Raqune
    Raqune Junior Member
    29
    Portland Oregon
    My 2010 Prius just turned over 206k/mi. I was getting misfire on cyl 2 code. It started to occasionally have the death rattle on startup if it sat for a few days. Other than that it was running fine, getting about 43mpg mixed driving. I was planning to do the EGR system & I/M cleaning and change sparkplugs soon. I left for work @ 4am in freezing weather, about 5min into drive I noticed the over temp light come on for about 10 seconds. Based on internet research I expected water pump was going out so quickly ordered a new one. However, when I looked under the hood, I noticed the coolant level was low. That was something new. The hose from reservoir that wraps around front of car and connects to small metal tube on larger metal pipe below EGR cooler had a pinhole leak in it with some signs of dried coolant residue on hose and on top of PSD so I assumed (hoped) that was the culprit. Ordered hose and started disassembly. Plugs looked pretty good, 2 from cylinders on PSD end had light brown crust on negative electrode but otherwise looked great, other 2 looked very clean. IM had typical oil pool in bottom, EGR ports were open but somewhat restricted. EGR cooler was somewhat restricted, but light still showed through clearly. Over-all not bad I thought. Guessing this service had been done before we bought car with 85k/mi on it. Since I had slightly elevated oil consumption (maybe 1qt / 5kmi) I set all 4 pistons @ mid-stroke & put MMO (Marvel Mystery Oil) and Chemtool B12 in cylinders to soak overnight, I also worked pistons up & down about 1/8 turn to work solvents into piston rings. I used an eductor (vacuum venturi) to suck all the liquid out of cylinders after I was done soaking them. Everything cleaned up nicely, new PCV valve, IM, EGR & water pump all went back together fine.
    At this point I wanted to spray chainsaw gas mix oil into cylinders to pre-lube cylinder walls before putting (old) plugs in (for initial "dirty" start-up). While baring engine around to get pistons to BDC before spraying oil mist into cylinders I heard what seems an unusual noise. From above I thought it was coming from PSD area, so I removed inspection cover for flywheel to see if damper assembly might have broken springs laying inside. But when baring engine over from underneath car the sound seemed more like it was coming from front of engine, possibly timing chain cover? I would describe the noise as a "clunk".
    YouTube Link to short video of flywheel to show speed and direction while I was baring engine back and forth:
    Is this normal, or is something bad going on with timing chain? I could have forgotten, but don't remember this noise when baring engine around for piston soak process.
    Also, after more reading on PriusChat I fear I might have a failing head gasket. Cooling system seems to hold pressure and vacuum, but AI says it is common for head gasket failure on Gen 3 Prius to only show up when engine is hot. I was planning to put it back together, warm up engine, then pull spark plugs to inspect cylinders for coolant seepage while system is hot and under pressure when this noise showed up. Now I'm a bit afraid to run engine.
  2. Mendel Leisk
    41,865
    Are you losing coolant?
  3. Mendel Leisk
    41,865
    Retyped, see you ARE losing coolant.
    Probably head gasket failure, leaking coolant into combustion chambers. If the damper (aka "flywheel", subject of your video) has failed, the head gasket leakage has likely been for some time. There may also be bent piston arm.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,466
    6,564
    Texas Hill Country
    I would not have put all that oil and magic additives in the cylinders. It will not help anything and could cause hydrolock.
    Ai is lying to you. Remember Ai is taking lots of forum advice and wrapping it in a wrapper of proper english. The advice is often wrong on specific subjects like gen3 Prius.
    A borescope inspection with a quality articulating tip, used in a cold engine and with a manually pressurized cooling system is the only good gen3 hg test.
    I would put it back together and drive it since you found a coolant leak. After a recurrence of symptoms, borescope it or have a hybrid shop do it for you.
    Car Care Nut HG Borescope at 660s
    South Main Auto
    Excellent Borescope Footage at 6:50
    Honda Misfires on Coldstart Only
