Clunking noise when turning right
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by ken2023, Sep 20, 2023.
  1. ken2023
    ken2023 Junior Member
    67
    49
    new jersey
    2023 Prius Prime
    XSE Premium
    New Gen 5, started at around 700 miles. On some right turns, not all, will here a clunking noise from the right front wheel area. Seems to only occur when the turn where the pavement is uneven -- doesn't reproduce when turning in a tight circle on level ground, which I'd expect from a CV joint. Will take it into the dealership at some point soon. Disappointing, Toyota usually has a very high finish level for their cars. Curious if anyone else has had a similar experience. Visually inspected the stabilizer linkage, CV, tie rod, everything looks solid.
