Clunking sound when braking
Discussion in 'Gen 3 Prius Main Forum' started by ES44AC, Sep 6, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    I am noticing a sort of clunk or knocking noise from under the hood when I hit the brakes. I thought it might be the pads, but it comes from under the hood .It only makes the sound on the first touch of the brake, once you have your foot on the pedal it stops the noise. It does this every time on the first application of the pedal.
    Is this sound normal? I don't recall hearing it when I test drove the car, maybe it's been there all along and I am just now making note of it.
    Thanks to all :D
    kenoarto likes this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    According to my dealership service department,,, yes it is normal.
    I too thought it was the pads slipping around but they say it is the brake actuator doing its thing (if in fact it is the same sound we are hearing). Considering the prius really just simulates braking (while regeneration occurs) I gave them the benefit of the doubt. ;)
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    It's rust build-up. Usually its accompanied by some noise as well. If you've noticed, it almost always goes away after the first or second brake application.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The next time this happens, when slowing for the next stop put the car in neutral. This will disconnect the HV battery which will disable the regen braking and force the friction brakes. Do this a couple of times and this will help remove any rust on the rotors and help keep the calipers from sticking.
    mad-dog-one likes this.
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Follow this method and note whether the clunking sound is eliminated. This will isolate any problem with mechanical braking by eliminating regen braking.
  6. ES44AC
    ES44AC C.A.U.S
    319
    77
    No it doesn't go away ever. I can sit in my garage and depress the brake and each time I do it I hear that noise.
    I will try what the others suggest but I have my doubts about it working.
    Thanks
