Clunking when braking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cardana24, Nov 4, 2015.
  1. cardana24
    cardana24 Junior Member
    91
    Charlottesville, VA
    Hey guys, I have an 06 Prius and this problem seems to be getting worse. Often times when I press the brakes I am having a clunking noise coming from the engine bay. It does not happen ever time that I press the brakes but it does happen most times now. The clunking cannot be felt in the brake pedal or the steering wheel, but it is quite loud. I don't know these cars well enough to know if this has something to do with the regen braking system or not. The CEL light is on in the car for a catalytic converter code. The only other thing I have noticed that may be out of the ordinary is that when the ICE turns off at a stop it is quite noticeable, it seems to shudder and the car shakes a little bit. This is my first Prius and I bought it in non running condition, so I am not sure what the normal is. Since owning the car I have replaced the transaxle, but beyond that I have only done normal maintenance. Any troubleshooting advice?
  2. Mendel Leisk
    41,912
    Maybe an engine mount has some play, maybe connected to the transaxle replacement?
  3. cardana24
    91
    Charlottesville, VA
    Possibly, I will check that. I should also probable describe the noise more like a popping noise rather than a clunk. It sounds like something popping from out of a bind. It does not always happen as soon as I touch the brakes. I can push the brake pedal sometimes and it will happen right away. Other times it will happen mid braking, I can push the brake pedal and be slowing down and it will make the popping noise before coming to a complete stop.
  4. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    ICE on/off should be relatively smooth. Have you cleaned the throttle body and changed the plugs? Maybe egr or pcv...
  5. cardana24
    91
    Charlottesville, VA
    I agree, I think it should be smoother than it is. I don't really think the ICE shaking issues has anything to do with the popping noise but I just thought I would throw it out there incase it does. My plugs are new and the throttle body has been cleaned out recently.
  6. David Woodlee
    David Woodlee New Member
    Fort Collins, CO
    Not to revive a dead thread--but were you ever able to figure out what was causing this? Mine is doing the exact same thing you have described.
