CMU study finds small battery PHEVs and hybrids the least-cost policy solution to reducing gasoline
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 30, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Source
    If the purpose of existing federal PHEV subsidies is to reduce gasoline consumption, this implies that the policy subsidizes 4 kWh battery PHEVs at ~$1.25 per gallon saved while subsidizing 16 kWh battery PHEVs at roughly $4.50 per gallon saved, ignoring indirect effects. It is clear that federal subsidies are not currently aligned with the goal of decreased gasoline consumption in a consistent and efficient manner. Other relevant policy objectives, including reduction of emissions externalities, encouragement of technology development, and job creation do not show clear benefits of favoring large battery packs over small battery packs.
    The authors suggest that redesigned policy should consider:
    • Subsidize usable capacity, rather than total capacity. The Chevy Volt, for example, uses only about 65% of its 16 kWh capacity in order to improve safety and battery life. However, current federal subsidies are tied to total battery capacity rather than usable battery capacity or AER—i.e., it incentivizes the use of larger battery packs.
      Subsidizing usable capacity would remove the disincentive for automakers to figure out how to use a larger portion of the battery. Alternatively, subsidizing based on AER (as measured in a standardized test) would also encourage automakers to make vehicles more efficient, and removing the exclusion for lower-capacity lower-range vehicles would be more consistent with potential benefits.
    • Subsidize estimated gasoline savings rather than battery capacity or AER. PHEVs have diminishing returns in gasoline savings as battery capacity increases. Subsidies intended to generate gasoline savings would be better if tied to estimated gasoline savings rather than battery capacity or AER, the authors suggest, and subsidies that are tied to battery capacity or AER should avoid a fixed rate per kWh or per mile and instead reflect the structure of diminishing returns.
      However, they add, methods for estimating gasoline savings may be controversial, and depending on what reference point is used, subsidies tied to gasoline savings could have unintended consequences, such as the potential for separate reference points in each vehicle class encouraging consumers to purchase larger vehicle classes.
    • Consider temporary larger subsidies. The current subsidy of $2,500 for 4 kWh (~$1.25/gal saved) and $7,500 for 16kWh (~$4.50/gal saved) pays prices substantially higher than US oil premium estimates of $0.37/gal ($0.08–$0.96/gal). Subsidies intended to generate gasoline savings would preferably be comparable to the social value of gasoline savings (and the value of other social benefits). To the extent that larger subsidies are able to kick-start adoption and sustainable market acceptance of plug-in technologies that would not otherwise be adopted, temporary larger subsidies may be warranted. But the magnitude or duration of this dynamic effect remains highly uncertain.
    • Target the goal, not the technology. More efficient policies generally target the policy goal, such as gasoline displacement, directly rather than a proxy, such as battery size.
      On economic efficiency grounds, subsidies are justified insofar as they correct for positive externalities, such as innovation knowledge spillover, and research funding is an alternative to subsidizing sales for achieving this effect.
      A more efficient way to address negative externalities is to apply Pigovian taxes (e.g., a carbon tax), which would increase the price of gasoline and make plug-in vehicles more competitive in the marketplace while encouraging the most efficient responses to reducing externalities, including not only alternative powertrains but also efficiency improvements and incentives to drive less and purchase smaller vehicles (as well as to make changes in other sectors of the economy). They authors acknowledged the political challenge of increasing or creating a tax.
    • CAFE. Considering the presence of binding CAFE standards, the authors raised the question of whether EV subsidies will provide any net gasoline savings for the foreseeable future
    Ignoring interactions with CAFE policy, HEVs and PHEVs with low AER and only home charging generally provide the largest direct gasoline savings per dollar spent, offering both lower costs and lower gasoline consumption than CVs, depending on the consumer’s discount rate. It is therefore possible that incentivizing a larger number of consumers to purchase HEVs or low-AER PHEVs would save more gasoline under a fixed policy budget than incentivizing a relatively smaller number of consumers to purchase high-AER PHEVs. However, given a fixed market of electrified vehicle adopters, if more gasoline savings is needed than what can be achieved with HEVs and low-AER PHEVs, additional savings can be achieved more efficiently by paying for additional AER than by paying for extra charging infrastructure.
    Comparison of current federal subsidy to base case assumptions showing lifetime fuel savings
    john1701a, lensovet and priuskitty like this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    So.....size does matter..... I was paying $36.00 a month on gas before I got my PIP, now I'm paying $15.00 a month for electricity....and filling my gas tank every six months with 5 gallons of gas.:D
  3. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    I agree with much of that as far as it goes. However, some aspects will simply be abused by manufacturers to the detriment of consumers.
    For example, if you give the credits based on usable capacity, companies will pit engineers vs accountants. They will give more usable capacity, even though it is worse for the longevity of the battery.
    It would be far simpler to simply assign a carbon tax. Electricity would be more expensive in high coal states leading to less benefit to EVs, yet far greater benefits to the cleaner areas.
    Easier to manage, less regulation, not additional temporary incentives required.
    Of course, this will never happen as it requires political bravery (sigh).
  4. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    We could all just drive around in subsidized Prius HEV if the goal was simply to reduce oil imports. The way I look at it is the true goal of Congress is generally to create US jobs and US business opportunities, for example putting ethanol in gasoline. You can see historically from the way Congress designed the first Hybrid tax credits, there was a humongous barrier put on Toyota re: numbers of cars sold per manufacturer. The authors sound a little naive thinking the goal is simply gasoline savings.
    John Hatchett likes this.
  5. John H
    John H Senior Member
    2,208
    558
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It is not just about gas saving. They also took account of emissions and social benefits as well (if not in this one, in previous paper). I thought their suggestions for improvements are sound and not bias. Focusing on goal instead of technology is what I have been saying.
    What's wrong with subsidized HEV? It represents 3% of the market. If it reaches the goals, it deserves the incentive. We need more people saving gas, reducing emission, increasing energy security, etc...
    dbcassidy and lensovet like this.
  7. John H
    2,208
    558
    Should we withdraw our support of jim335 expanding the PiP's battery, and not seek tax credits for add-on batteries?
    My observation is that the size of the battery offsets gasoline usage optimally when it is aligned with the driver's profile.
  8. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    The report, like the one from nearly ago, is based on a faulty assumption
    It starts off with
    "If the purpose of existing federal PHEV subsidies is to reduce gasoline consumption,"
    Which it interprets as for the subsidized cars so produce to reduce gasoline consumption..
    This is a false assumption and nothing that follow matters. The purpose is to develop technology that will, in the long run, lead to energy independence. The report, just like the last one, ignores the changes the subsidies will lead to in the industry. Giving larger subsidies for riskier but more efficient designs, is about providing incentives for organizational/social change. Its not just the cars produced but leading to new designs and lowering the costs for the next generation of cars. Its an INVESTMENT, not a onetime purchase of lower gas.
    Hybrids and low-risk PHEVs don't need subsidies to be cost effective for their manufactures.. but after a decade they have only small overall market penetration.
  9. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    Not only do we not have incentives for HEV, we have penalty, as follows:
    When you buy a Prius vs. say Corolla you are paying $4000-$5000 more for battery+elec motor etc
    Here in VA I pay annual property tax based on car value so I probably pay $1000 more taxes for the Prius too (5-year cumulative extra tax estimate).
    Let's face it, the purpose of EV subsidies is to give US manufacturers (batteries+cars) a boost in the EV/PHV area. We are not going to fork over too many US stimulus advantages $$ to foreign companies. The way I look at it, gasoline is still the best/cheapest, although we complain like crazy. So we are stimulating US EV business, if this does not work we are not going to give the taxpayer money to Toyota, rather we fall back on gasoline.
    PS- I guess we will subsidize Nissan for example if they build in USA
    Adam Leibovitch likes this.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think the assumption is sound because the goal of the prior successful federal subsidies (for HEV) was to reduce gasoline consumption. The amount qualified was based on the difference in MPG rating from EPA.
    There are separate subsidies for R&D and manufacturing. Are they not enough? Then increase it there. If it is not possible then, that technology is not ready.
    The incentive for buyers have always been for the purpose of saving gasoline (hence reduce emission). Sure, it also helped to offset the extra cost but the amount was tied to the goal (not specific technology).
    dbcassidy likes this.
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yea, that's what it looks like to me as well. Battery R&D are coming out from DOE labs. LG Chem was given a license (undisclosed) to manufacture it. They get subsidies (per cell) to manufacture it. Is that not enough? As you pointed out, Nissan also get cheap loans and state incentives to build motors and batteries in the US so it cannot prevent subsidies from going to foreign companies.
    Why do we need to give out another $7,500 consumer incentive without any attachment to the goal of reducing gasoline?
    Gas can be saved two ways. 1) Increase gas engine efficiency. 2) Displace it with electricity using battery. The prior HEV tax credit focused on #1. The current tax credit focus on #2. For pure BEVs, focusing on just the #2 is valid.
    However, for plugin hybrids that use both fuels, both goals #1 and #2 are needed. Focusing on the battery size alone is not going to be effective (nor focusing just on #1). Gas engine efficiency is equally important. I think the author's suggestions for a redesigned policy makes sense.
  12. markabele
    5,084
    1,782
    Nebraska
    ^^^This!!!
    I see a future plug in hybrids that have unlimited range in terms of gasoline but come in a variety of battery sizes that best fit your needs, kind of similar to how you can buy an iPhone/iPod/iPad in 16, 32, 64 gb sizes.
  13. drinnovation
    2,027
    586
    65
    CO
    The approach included 3 prongs, R&D, Manufacturing and customer-pull. The prior R&D based funding llike PNGV never led to real products because there was not an incentive to sell, just funding to do the R&D. Tying a big chunk of money to actually selling products and getting customers to buy the tech, generally at slightly higher prices, means the R&D is turned into practice and receives customer "investment" too.
    The incentive for many buyers has nothing to do with reducing emissions.. many want to get off of oil for other reasons.. Energy independence, what is what bush was pushing, is not about emissions, its about where our money goes and who we depend on.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    A new study from CMU together with Ford says the same thing. Plugin with a small battery is best due to the carbon concentration in the current grid. HEVs provide the best bang for the incentive buck at the current gas price.
    This research was supported by National Science Foundation grants from the Foundation’s Material Use, Science, Engineering and Society program, the CAREER program, and the Graduate Research Fellowship program. Support was also provided by Ford Motor Company, Toyota Motors of America, and the Steinbrenner Graduate Fellowship.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That's fine as long as it is tied to the goal and not a specific technology (battery size).
    So, gasoline gallons saved was indeed the goal. CO2 output is directly related to the amount of gasoline burned. A gallon of gas (about 6 lbs) produces 20 lbs of CO2 (factor of about 3x), no matter how you combust it.
  16. Rebound
    Rebound Senior Member
    3,972
    2,627
    Portland, OR
    I think the government incentives are properly scoped. They allow a car maker to determine costs early. This is nascent technology and the important thing at this phase is to produce quality cars.
    As it is, reducing effective capacity and charge/discharge rates puts a car at a competitive disadvantage. But I don't think now is the time to sacrifice longevity for performance/efficiency. Now is the time to prove that the technology works reliably.
  17. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The same basic technology was also licensed to BASF (German chemical company), Envia Systems (Silicon Valley battery startup), and Toda Kyogo (a Japanese maker of cathodes).
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It would be best if tax credit works at individual level. I don't think it would be plausible so the best is going by the EPA figures.
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I agree on the quality and the need to prove that it works with the early adopters. Should the incentive amount be sized for the early adopter or the mass market?
    I think the current $7,500 tax credit for 200,000 vehicles (another 200k at half the amount, then another 200k at 1/4) is sized for the mass market, skipping the early adopter stage.
    In the meantime, other technologies (HEV, Diesel, etc) are ignored. I am not against incentives for the plugins. I think it needs more support because it is a nascent technology. I just think some of the money could go toward other technologies that could also save gas, hence not ignoring the goal (and not picking winners and losers).
  20. drinnovation
    2,027
    586
    65
    CO
    Energy independence is not as directly tied to fuel efficiency and definitely not tied to reduction of CO2. (which is what I was pointing out). Shifting to other sources can be almost neutral in CO2 or even a bit worse (e.g. coal vs gas), but can still lead to independence.
    A different way of looking at it is how many people would buy a mile phev that would not have bought a HV and looking at the savings compared to the other vehichle people would likely have bought. The study did not consider actual buying, just compared to the average. If the funding had been focused on low-range PHEVs, it would more likly just appeal to those already buying HVs -- so the saving would be smaller compared to their likly purchase.
    While some of the Volt owners, would have been in an HV, many switched from non-HVs and the "power" and drive experience is a big part of getting them to swtich.
    The CMU study, like last year, did not look at how investments pay off in the long run, or how it influences purchase decisions -- i.e. they ignored how the market actually works. If you want a lower-cost greater gas reductioin, just put a huge tax on SUVs or any low MPG car -- then you need no infrastructure and no incentives (and get no real investment in R&D). Of course that does not work either because it also ignores how the market works..
