Sold Coastal Tech Prius electric mode 2004-2009
Discussion in 'Private Sales' started by Bunce, Dec 15, 2018.
Thread Status:
Not open for further replies.
  1. Bunce
    Bunce Active Member
    321
    185
    Oregon
    I have an unused/uninstalled Coastal Electronic Technologies electric mode kit for a 2004-2009 Toyota Prius.
    The new Toyota Prius is sold in many countries around the world with the option of letting the driver select times when they would prefer to operate the car without the engine running. The intention is to allow the driver to move the car out of the garage, or even out of the neighborhood, without the engine starting to awaken others. It is also a wonderful way to demonstrate the capabilities of the hybrid powertrain to passengers learning about the system for the first time. This factory option is currently not available for buyers in North America although the programming for it is still included in the computers which control the hybrid system. This kit allows you (in just a few minutes) to activate the electric feature of your Prius and drive for short distances. The software already present in the car will automatically restart the engine when the battery needs to be recharged or if you need to accelerate quickly. The electric only feature can be turned on and used up to a speed of around 34 mph at which time it will automatically turn off and the car will operate as usual.
    The electric mode kit is designed for ease of installation and includes the necessary pin and connectors to complete the installation. Color photos and step by step instructions explain how to insert the missing pin and clip on two wires using simple wire taps. No wires are cut and very little disassembly is necessary to activate this feature. Once installed, the kit will create two possible uses for the "Cancel" function of your cruise control stalk. If you pull the cruise control stalk toward you (as when using the "Cancel" feature) and hold it for more than two seconds, the electric only mode will be signaled and the factory software will shut down the engine (or prevent it from starting if you are just turning on the car). This method will also turn off the electric mode when desired. The normal operation of the "Cancel" feature when using the cruise control is unaffected by the addition of the circuit and will continue to function as usual.
  2. Bunce
    Bunce Active Member
    321
    185
    Oregon
    $35 shipped (within the US)
    SFO likes this.
  3. Bunce
    Bunce Active Member
    321
    185
    Oregon
    Sold. Thanks all.
  4. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    WHERE can i get this switch...before I got insane trying to accomplish short range EV only mode on gen 2??? Thanks!
  5. bisco
    49,399
    you can't, and it doesn't work like that anyway. pretty much a novelty, and mostly useless.
Thread Status:
