Coastaltech EV-mode mod - observations
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Hi-Bred, Dec 2, 2005.
  1. Hi-Bred
    Hi-Bred New Member
    I've been using the Coastaltech EV-mode switch for a few months now, and it works great, no complaints (except that it didn't work at first because I hadn't pushed the pin down far enough in the socket. Upon shoving it a little further, it started working).
    I was looking forward to gliding all the way down the hill from my house (about 2 miles, 1000 ft. elevation drop). But the ICE would always start up about 1 mile into the drive. Finally, I figured out that the car will cancel EV-mode when the battery charge reaches 100% (this is probably a rare situation, the only way you can do this in EV mode is to drive downhill with the brakes on for a long time).
    Well, I figured out a way around it: putting the car in Neutral prevents the battery from charging. In fact, it discharges the battery due to the power required for braking. Once it gets down to around 50%, I put it back in Drive, then let the meter climb back up to that lovely shade of green. Using this method, I can delay the battery getting fully charged, and I can drive the whole trip without using one drop of gas B)
    -Dave
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Dave,
    Although your technique clearly works for you I don't know that it's the same I, personally, would use.
    You are using friction brakes, exclusively, during that downhill run in neutral. So you may not burn a drop of gas, but you may be unnecessarily prematurely wearing your brakes.
    I suggest using your EV mode to intentionally drain the battery down to about 3 bars BEFORE you begin your descent down the long grade. Then, let speed build in a glide as high as you're comfortable letting it get. Then use regenerative braking for as long as it will last. If the ICE spins up then let it. It will consume little gas in doing so.
  3. darwin100
    darwin100 New Member
    131
    I am wondering just how the EV is useful. My impression is that it allows one to use the electric mode mostly.
    I do a lot of starting and stopping running chores so the ability to use electric would increase milage.
    If this is installed can I use electric alone and count on the computer to start recharge when battery needs it? or does one have to moniter the battery ones self...not a good prospect for me.
    Is this easy to install ( I am female, 63 years, but did surgery so good with hands).
    Does anyone have any thoughts on this?
    thanks...
  4. jwe8f
    jwe8f New Member
    174
    Indiana
    It's good in limited applications, like moving a car across a parking lot. "Pure EV" mode is only good for a mile or two. I just used it today to chase down my mailman. He had knocked on my door, but I didn't answer quick enough. After he left I got dressed, put on my coat, and got in my car to go find him. Found him a few blocks away...
    In my opinion, it isn't the easiest thing to install, but with a little patience you can do it.
    The car will start the engine when required, like discharge of the battery, need for acceleration, or going above 30-35 MPH. It's all automatic. You can also manually disable it. It also will automatically switch to the battery screen so you always know the state of your battery. However, as I said, it will switch out of the mode when the battery starts getting drained, so you don't have to monitor anything.
    The nice thing about the Coastal mod is it is relatively transparent. You just connect 3 wires, and then use the cruise control stalk to enable/disable it. The trick is getting to those 3 wires. You should be able to handle it, though... :)
  5. jimgraffam
    jimgraffam New Member
    131
    Sterling, MA
    I'll second that. I just installed mine today :D
    My observations (in no particular order):
    1) I really wish my hands were 25% smaller.
    2) Patience is indeed the key when "negotiating" that blankity-blank connector to a position where you can work on it.
    3) More patience while seating the pin. After reading several other threads, this seemed to be the critical part. My instructions included a picture of how deep the pin needed to go. I was constantly concerned that I was either going to pull other pins out or was going to ruin the connector with the adjoining pins (some open). Neither happened.... I was careful
    4) The first step is the one where you're a bit uneasy... pulling the bottom plate off the dash. After that... you start to feel more like you're not gonna ruin the car.
    5) If you have a nice big garage and have enough lighting... that would be my recommendation. Here in Massachusetts, it was mid 30s and the car had been outside for a bit while I cycled fall/winter junk to/from the garage/shed. I think it would have been easier to move the wires around if they'd been nice and warm... not to mention improve the feeling in my fingers.
    Seems to be working like a champ though.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I am exploring more and more uses for the EV, like when I go into the Green bars, I evoke the EV mode until I am in the blue area the pump the gas and go on. My limiting factor is the Engine Temp that drops when I am in EV or Glide mode.
  7. darwin100
    131
    I'll let you know......I thought I would go with coastal....I am still a bit uncertain if I would use it or if it is worth it..why have you put one in? I am thinking that I could use EV for all my start and stop chore trips....am I mistaken?
  8. jwe8f
    jwe8f New Member
    174
    Indiana
    Someone suggested a 'auto' EV switch that would engage until disrupted at every 'READY', but they were shot down... So there must be some problem with it!
  9. jimgraffam
    131
    Sterling, MA
    I have not yet explored all the ways to make the EV useful (i.e., beyond the cool factor... which had some share in the reason behind my purchase).
    That said, the main reason why I went EV was where I live. I live about on the top of a hill about a mile after the hill crests on locally flat terrain. I need very little oomph (other than my driveway) to get to the downslope so I can recharge there and start my morning commute at the bottom where I would need the ICE anyways to get up to speed, negotiate another hill, and merge onto the highway.
    To make matters worse, the bloody ICE just loves to stay on on my way home after I crest the hill. Maybe I'm just goofy, but it kills me to have the ICE on as I drive past my neighbors on the flats. :( I'd brought this up in a thread I started and EV seemed to be "an ideal condition" per Dr. Fusco :) http://priuschat.com/index.php?showtopic=12627
  10. Tideland Prius
    16,445
    hehe. Not sure if you were joking or serious but I don't think he'll wear the brakes that fast since we're not using it half the time anyway. Do you mean overheating?
  11. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The brakes would not normally wear with the regen braking, however, Hi-bred has stated that he ran the car in neutral so the brakes he applies are the friction ones.
  12. Hi-Bred
    Hi-Bred New Member
    You're right, I didn't consider the wear on the brakes. I've already tried the other option (sucessfully) - draining the battery before the downhill slope - but I felt a little silly adding time and distance to my trip just so I could stay in electric mode. Of course, I would feel sillier taking the car in for worn-out brakes.
    Anyhow, I've found that the EV-mode does in fact increase my overall mileage, but not significantly. Mostly it enables me to set new MPG records on my way to work - a 19 mile drive from Altadena to Burbank CA. Best so far: 86.3 MPG one way (-1000ft elev), 55.0 MPG round trip.
    -Dave
  13. joelparks
    joelparks New Member
    82
    Bedford, MA
    I look at it this way: as much as I wanted a battery-electric-vehicle, or a plug-in-hybrid, my Prius is still a gasoline car. Given that fact, what is the most efficient way to operate the gas engine? ICE engines like to be warm (hot) and avoid constant starting and stopping. Therefore, I try to maximize the run-time of the ICE each time it comes on.
    So I use the EV switch to suppress the ICE when I'm quite sure that running it now would be less efficient than running it later.
    For instance, I live at the top of a hill. When I leave the driveway, without having engaged EV, if the ICE has completed it's initial warmup cycle it shuts down for at least a minute and maybe two, before starting back up to get me up a little hill. At which point it shuts down again for another mile or so. So instead I pull the cruise control stalk to engage EVmode immediately when I start up the car in the driveway. The ICE never comes on, I glide down the hill and use gentle battery-only mode up the rise. Then I glide down the next hill and when I get near the stop at the bottom, I pull the stalk again and dis-engage EV mode. The ICE starts up and I can accelerate from the stop sign and merge with traffic on the main road.
    Then after a bit I get to a point where there are 5 lights in a one-mile stretch, unsynchronized. As soon as I have to stop for one, I pull the stalk again and engage EV mode. I don't disengage EV until I'm through all the lights, since if I were to stop for another one (likely) the ICE would again shut down, and it would have been operating relatively inefficiently for the time between lights.
    The other reason to use it is if you are only going a short distance (less than a mile) and you know you won't draw down the main battery far enough to have the computer override the EV mode and start the ICE during that drive.
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I found a new use for the EV mode. I was in the parking lot of the Nursing Home my Mother is at, and when I came out a bunch of people where crowed around their car next to me and behind my car. One of the people was a little one about 4 or 5 and I told her to be very careful when I back up because my car does not make any noise. I got it hit the EV and pulled out and drove around the family as they gathered together. The kid took it great but the adults looked stunned, as I slowly pulled away at a slow speed to make as little tire noise as possible.
  15. YonatanHakatan
    YonatanHakatan New Member
    I recently ordered the EV kit, and I'm planning on having it professionally installed. Yet, I wonder about the implications on my warranty -- would it be totally void if I were to go through with the installation?
    Perhaps this has already been brought up, but when I typed the owrds "Coastal" and "Warranty" into the forum search, no results came up.
    Thanks in advance for your input!
  16. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Probably not because the switch is build into the car and just offered as a feature in Japan and Europe. Toyota would have to show that the EV mod was the cause of the damage. Also, the mod is REALLY easy to install. You could save a bit of money by doing it yourself. It took me 30 mins start to finish and I'd done anything like that before.
  17. YonatanHakatan
    Thanks, Tripp. I simply don't have enough confidence in myself to do even the simplest work like this, and I'm happy to pay if only to spare myself constant worry about it having been done right.
    I actually asked the service dept. at my local dealer, and while they couldn't give me an official answer, were very confident that this would void my warranty; their logic was: even if it's standard on foreign versions of the Prius, if you take it upon yourself to add a feature like this to the car, you're responsible for any problems with the hybrid system that may occur further down the road. I of course realize that they can't be objective about it, but the process still seems risky to me. Even if EV mode itself never causes any problems, I'd hardly be able to blame Toyota if it considered such a modification as so significantly altering the system they sold me that they can no longer be held responsible.
    Which is why I ask, and why I'm still hestitant.
  18. joelparks
    82
    Bedford, MA
    If I were you I would continue to ask around. Dealers have a lot of leeway here; I've read posts on PriusChat from Toyota Prius Technician who installs EV switches for his customers, on request, with the knowledge of the dealership management
  19. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(Hi-Bred @ Dec 2 2005, 10:03 PM) [snapback]166772[/snapback]</div>
    Since when is electric power required for braking?
