Code 1121 and C1391
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vic213la, Jun 20, 2022.
  1. Vic213la
    Vic213la New Member
    Los angeles
    Hey guys so somehow I end up with this bad abs module according to the codes . But I have changed it 2 times from the ones I’ve bought on eBay and when I installed them I still get same codes they didn’t leave the display screen after replacing the abs module. And the first time with first part the break pedal would go a little too low and can feel car wasn’t breaking until pedal was deep.
    today I switched to another abs module and still same codes and I bled breaks and the break pedal is now little hard but it lags to break and when it breaks it only does it with left caliper, makes tire slide and the right side keeps spinning while pedal is being pressed completely.
    Any suggestions guys ?
  2. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    Same problem here all the parts are not new and probably have same issue as original . Theyres a guy on eBay who say he can rebuild he sent me two parts to try . I will do soon. But this is how most Gen 2's go to the junkyard there's many there and I bet most of them have this problem and not blown engines or batteries but usually the brakes because nobody can get the parts to fix it seems that's correct
  3. Vic213la
    Vic213la New Member
    Los angeles
    I’m thinking might be the brake caliper . Idk what else might be bad
  4. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    Did you use Techstream (or another professional-level scan tool) to do a full system bled?
  5. Vic213la
    Vic213la New Member
    Los angeles
    No I did it manually the old school way.
  6. ChapmanF
    17,326
    That won't bleed the brakes. There are valves inside the actuator that won't be open unless the bleed procedure is being run. Air behind them won't be bled out. The system is pretty much guaranteed to work weirdly/badly when not bled.
  7. Vic213la
    Vic213la New Member
    Los angeles
    How can I bleed them? The right way? Do I need special tools?
  8. ChapmanF
    17,326
    You need a device that can connect to the car's OBD-II connector and command the brake system to go through its bleed sequence.
    A laptop with Toyota Techstream is the obvious choice, but there is a recent thread with some alternate recommendations too.
  9. Vic213la
    Vic213la New Member
    Los angeles
    so there is no way, there can be a manually done brake bleed without this Toyota techstream device ? Do all Toyota techstreams work for all Toyotas ? Or do I have to buy certain one for the specific car .
  10. ChapmanF
    17,326
    There are alternatives to Techstream that you can find listed by following the link I gave above.
    Generally, a version of Techstream ought to work with any Toyota car that isn't newer than that version of Techstream. And it might even have a lot of its functionality still with newer cars too, though that's a gamble.
    Sometimes there can be some Techstream operations that might not work right depending on the dongle that is being used with the computer running Techstream.
