Code 1211 Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by h louie, Oct 30, 2017.
  1. h louie
    h louie New Member
    california
    I have a problem with the coolant valve. 2008 prius
    I have installed a new one but I think I switched the top two hoses and ran it for maybe 10 miles.
    All this time , I been getting the red triangle off and on.
    I switched back the hoses with the top one going to the pump and the second one going to the engine.
    I been still getting the red triangle off and on. I been trying to bleed the coolant out with the bleed plug and using the 6 mm on the radiator bleed valve.
    I didn't do the chr pump fill yet. Would the air in the coolant system cause no hot air when I turn up the temp.
    Problems,
    1)Red triangle off and on.
    2) Heater does not work.
    Any suggestion would be appreciated.
  2. JC91006
    16,496
    8,404
    It sounds like you have to make sure the hoses are in the correct position and also you need to add more coolant.
    Raytheeagle likes this.
