Code C1344-Tried to Bleed 'left rear wheel'-It was clogged-lots of black gunk came out
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 9, 2025.
  1. ski.dive
    ski.dive Active Member
    958
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Got Code C1344-
    I Tried to Bleed 'left rear wheel'-The brake line was very clogged
    After lots of brake pedal pumping- lots of black gunk came out of the line.
    All the other brake lines had clean break fluid--except the 'left rear wheel' that was clogged
    ***What would cause this?
  2. Brian1954
    Brian1954 Senior Member
    1,759
    684
    South Central PA, USA
    Did the C1344 code and the warning lights on the dash go away after doing the brake fluid bleed?
  3. ski.dive
    958
    241
    I erased the code and the warning lights on the dash went away
    ***But my question is-what 'could cause the brake line to get clogged with all that thick black stuff ' -only in the left rear wheel?
  4. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    Is there any chance that somebody put in DOT 5 brake fluid and not DOT3?
