code p0300
Discussion in 'Generation 1 Prius Discussion' started by Dandrivem10, Aug 9, 2013.
  1. Dandrivem10
    Dandrivem10 New Member
    2002 Prius
    I
    Had this code show up after the warning light came on and then the light went away after two day, the car seems to be alittle sluggish now. I have read that this is a random engine misfire and it could be a bad plug anyone else have had this problem
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Yes, P0300 is a random misfire code.
    It could be any number of problems. Here's some info.
  3. BobThePrius
    BobThePrius Junior Member
    22
    Michigan
    This PDF is a great resource, thanks for posting. Any idea where I could find the full manual that this is taken from?
    Thanks!
  4. ChapmanF
    15,459
  5. ronlewis
    ronlewis Active Member
    872
    178
    texas
    2001 Prius
    Looks like you have an 07 but are researching in the Gen1 forum. Make sure you get a service manual for your year. The codes mean the same thing, but the service procedures may be different.
